People running Hondata S200 and S300 ECU's...
Old Jun 5, 2007 | 07:37 PM
Todd00's Avatar
I said I don't want a title!
Default People running Hondata S200 and S300 ECU's...
I'll keep it simple for now, but I'll elaborate later.
How many of you go through emissions testing and do you leave your Hondata modified ECU's in them?
Just curious about the OBD-II aspect and what happens when a state tester is hooked to them.
Old Jun 5, 2007 | 07:39 PM
vtec.dc2's Avatar
Default Re: People running Hondata S200 and S300 ECU's... (Todd00)
i don't htink you'll pass using obd1 ecu if required for obd2 scan. k series hondata is the only one i know that should pass ecu check
Old Jun 5, 2007 | 07:42 PM
Todd00's Avatar
Default Re: People running Hondata S200 and S300 ECU's... (vtec.dc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec.dc2 &raquo;</TD></TR><TR><TD CLASS="quote">i don't htink you'll pass using obd1 ecu if required for obd2 scan. k series hondata is the only one i know that should pass ecu check</TD></TR></TABLE>
Yes, and this is exactly what I needed to know in regards to the 97-01 Integras.
Old Jun 6, 2007 | 03:17 AM
AdeJong 03's Avatar
my 95 ls vtec with s200 passed smog but thats obd1 and obd1
obd2 to obd1 conversions are considered "illegal" so you wouldnt be able to use your s200 during smog
Old Jun 6, 2007 | 04:49 AM
Dave_B's Avatar
I run the S300.
In FL, we have no emissions checks either.
Old Jun 6, 2007 | 08:11 AM
exies's Avatar
Default Re: (Dave_B)
I need to do emissions every two years. So then what is the proper thing to do when you tune with Hondata when using an OBD2 in this case? Change back to OBD1 everytime emissions is due?
Old Jun 7, 2007 | 04:07 PM
ThatGuy4life's Avatar
Default Re: (exies)
DO you mean changeback to obd2 for emissions? That's what I did this year, I have a flly built type r motor running on a modified P28, when it came time for inspection i just hooked back up the stock P2T ecu and put in some stock injectors and passed the 2nd time around, failed the 1st time cause the ecu wasn't ready to be tested yet, so had to drive around a little bit more
Old Jun 10, 2007 | 05:01 PM
R-box's Avatar
I ran through emissions with my S300 this year (and hid it from their view - the R was throwing a CEL at the time on the stock ecu). When they plugged their equiptment into the plug behind the dash console, the computer wouldn't communicate with it, and they told me, "It must be a problem with our computer, pull forward please." So I was sweatin' it a little bit, but then they just did the gas cap test and considered me passed, HAHA! SUCKERS! I mean... I got lucky?
But I don't live in your state, so it could be different. Also, you could just try to run it through with the Hondata and see what happens - if you fail you have 30 days to figure it out for the free retest (at least that's how it is in my state).
Good luck!
Old Jun 11, 2007 | 12:22 PM
Black R's Avatar
25 Year Member
sadly, highly modded itr's need to have a kswap to pass emissions without slight of hand...
Old Jun 11, 2007 | 12:51 PM
nholmes's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Todd00 &raquo;</TD></TR><TR><TD CLASS="quote">How many of you go through emissions testing and do you leave your Hondata modified ECU's in them?
In California you will insta-fail if you aren't running the OEM ecu.
Old Jun 11, 2007 | 08:39 PM
robfrmny21's Avatar
in nys they hook up on obd2 car through the DLC connector , obd1 ecu will not have all the gizmos its looking for and it will fail on the spot
b16_swap
Engine Management and Tuning
Aug 20, 2009 06:50 PM
luckypon7
Aug 20, 2004 07:58 AM
streetlvlhatch
May 3, 2004 06:58 PM
integrarider
Jan 8, 2004 06:31 PM
RacerZook
Jan 25, 2003 02:28 PM
