engine swap
You are going to need time and money for starters. Pretty much everything from the engine you are swapping in. If you have to ask such a basic and repetitive question like this, perhaps this is not such a good idea to commence of a project of this sort.
you've got quite a project in front of you. Many people have gone from auto to manual, but it can be pricey if you have someone else do it, and doing it yourself sounds like a big headache to me. Are you looking at doing everything yourself??
there is a search function in the top right and a sticky at the top of this forum on faqs. Go check it out beacuse you will find the answer to a lot of your questions you have, if you have more come back and ask but this same exact question is asked like clockwork here.
all the mounts and brackets have to be from a 94-01 integra except for the top of the tranny since you have an automatic you need the auto-manual conversion mount from hasport or ebay or wherever or you can cut the bracket off the passenger frame rail and weld on the 5spd one and use the stock integra mount
