loud rattle from my exhaust
Old Jun 5, 2007 | 04:19 PM
lsturboswap's Avatar
Default loud rattle from my exhaust
my exhaust vibrates and hit up against my under body everything is screwed on tight i dont have a heat shield it makes a real loud and annoying sound i was thinking of putting some fire proof padding were it is hitting kind of like firewall padding what are your guyes ideas.
Old Jun 5, 2007 | 10:19 PM
crimsonv4mpire's Avatar
Default Re: loud rattle from my exhaust (lsturboswap)
i've got a similar problem with my exhaust against my front sway bar, answers might help me too thanks!
Old Jun 5, 2007 | 10:54 PM
truevietluv636's Avatar
Default Re: loud rattle from my exhaust (crimsonv4mpire)
that exhaust wrap stuff might work. i see people put them on the headers.
Old Jun 5, 2007 | 11:22 PM
::MYCORD::'s Avatar
Default Re: loud rattle from my exhaust (truevietluv636)
I would not recommend header wrap because that will eventually corrode the piping as it traps in moisture. For the OP, where exactly is the exhaust hitting? Are all the rubber hangers pretty tight or do they still have some give?
Old Jun 5, 2007 | 11:31 PM
beverlykarl's Avatar
get your headers wrapped. I will not only reduce your engine bay's heat but also lessen some worthless sounds,.
Old Jun 6, 2007 | 04:08 AM
mikeycivic's Avatar
Default Re: (beverlykarl)
I have the same issue. I dont know where the expletive the noise is coming from. I have taken off every shield underneath and it has an annoying rattle at low rpm's.
Old Jun 6, 2007 | 05:53 AM
crazyguy's Avatar
Default Re: (mikeycivic)
i dont think it is the heat shield..
i have the same problem and i found out that the rear section of the muffler is hitting against the rear lower control arm
Old Jun 6, 2007 | 06:07 AM
mikeycivic's Avatar
Default Re: (crazyguy)
yeah I never thought of that but I am going to put it on a lift and see where the f its coming from
ih8speedbumps
Jan 4, 2014 03:17 AM
Teggy00ls
Aug 5, 2009 07:42 PM
dhatb0ijohnny
10
Jul 10, 2007 06:24 PM
CTR-GSR
Nov 27, 2005 06:35 PM
