Hlp pleaze!
Old Jun 4, 2002 | 12:40 AM
EJ6HB's Avatar
Default Hlp pleaze!
Hey all, just wondering if the DC Sports 4-2-1 Headers from an EX coupe fit on D16y7 engine?! Thanks in advance!
Old Jun 4, 2002 | 02:02 AM
PROJECThX's Avatar
Default Re: Hlp pleaze! (EJ6HB)
The header will technically fit but theres a few things to keep in mind before putting in on.
First off the D16Y7 has its cat converter attached right under the exhaust manifold. In order to put the header on you will have to take out both the exhaust manifold and the cat converter underneath. The header will now be a direct fit however you will no long have a cat converter. Your engine check light will go on because you only have room for one sensor in the DC header.
Now... it is possible to buy a cat and attach it to the header so that you can have another sensor port and the check engine light will go out. However, because the stock cat converter is no longer where it should be your car will likely run rich (and will not pass smog). Again, you could (if you wanted) use the complete EX exhaust setup (header, cat, and cat back exhaust) because it will bolt right up; however, you will encounter a few problems when it comes to smogging your car and possibly you engine won't be running at peak power.
Hope that helps you.
Old Jun 4, 2002 | 02:09 AM
97hb's Avatar
Default Re: Hlp pleaze! (PROJECThX)
However, because the stock cat converter is no longer where it should be your car will likely run rich (and will not pass smog). Again, you could (if you wanted) use the complete EX exhaust setup (header, cat, and cat back exhaust) because it will bolt right up; however, you will encounter a few problems when it comes to smogging your car and possibly you engine won't be running at peak power. Hope that helps you.
If done properly, the car should not run rich at all, and there should be no smog issues.
Evon
Honda Civic (2001 - 2005)
Sep 23, 2013 09:59 PM
xelloss
Jul 26, 2006 12:07 PM
acme
Apr 1, 2004 08:04 PM
Jimmy
Jul 24, 2003 08:20 PM
