Ball joint screw ??
Old Jun 5, 2007 | 12:54 PM
free99's Avatar
Default Ball joint screw ??
am sure many of you guys have been thrue the same proble i can get the nut on the screw b/c it spins i tryed lowreing the LCA on a brick , puting electrical tape arund the scew i jst dnt know what to do next plz point me in the right direction thaks
Old Jun 5, 2007 | 01:22 PM
vrrodri's Avatar
use an air tool, I had that issue and it came off with no spining, or, get a cutting wheel and cut it off. The new ball joint will include a new bolt anyway
Old Jun 5, 2007 | 01:40 PM
free99's Avatar
i got it out i cant put it back in !!
Old Jun 5, 2007 | 01:43 PM
BubblegumTate's Avatar
Default Re: (free99)
Jack the control arm up so there is weight on the ball joint/control arm mating surface. Then crank on that bolt with an impact wrench . You're not really looking for torque here, you're looking for speed.
Old Jun 5, 2007 | 01:44 PM
bmoua's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by free99 &raquo;</TD></TR><TR><TD CLASS="quote">i got it out i cant put it back in !! </TD></TR></TABLE>
i had the same problem bro, i bolted it as much as possible and took it to a shop to get it put in.
Old Jun 5, 2007 | 01:45 PM
EJ7_1998's Avatar
ok this happened to me last weekend i was desperate wat u need to do is
1 put a jack under the lower control arm and raise it
2. bring a friend and tell him to step on the brake assembly ( basically just try to put presure on the wheel hub and then try to put it back in .u'll c that the screw wont move no more ...remember put pressure and at the same time screw the nut ...hope it helps
oh and if u wantb put some w40 so it could spin better
Old Jun 5, 2007 | 05:31 PM
vrrodri's Avatar
clean the threads well, that can help, and put some anti-seize on the threads.
Old Jun 5, 2007 | 06:23 PM
Bejita's Avatar
Get a new balljoint....It's obviously worn.
Old Jun 5, 2007 | 10:10 PM
crimsonv4mpire's Avatar
Default Re: Ball joint screw ?? (free99)
i usually use a jack under the lca, if it still slips i use the big prybar to but separating pressure between the lca and hub
Old Jun 5, 2007 | 10:16 PM
Team RS2's Avatar
Default Re: Ball joint screw ?? (crimsonv4mpire)
i just use a jack or use the vehicle weight to my advantage
Old Jun 6, 2007 | 03:47 AM
EE_Chris's Avatar
Default Re: (Bejita)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bejita &raquo;</TD></TR><TR><TD CLASS="quote">Get a new balljoint....It's obviously worn.</TD></TR></TABLE>
Old Jun 6, 2007 | 05:20 AM
D50boy's Avatar
Take a cut off wheel on a dremil and cut a slot in the end of the bolt so you can stick a flat end screwdriver in it to keep it from spinning. Use a box ended wrench to turn the nut as you hold the bolt with the screwdriver. Torque it down after it's tight and stops spinning. Use a cotter pin.
Old Jun 6, 2007 | 05:25 AM
blackKready's Avatar
Default Re: Ball joint screw ?? (D50boy)
if your replacing this balljoint which as was already mentioned , it looks like you should. just cut the whole stud and nut off flush with the spindle.
Old Jun 6, 2007 | 06:52 AM
free99's Avatar
thanks for all the help last nite i got in i got some w40 and cleand it out really good the screw and the nut after that i didnt even have to put presure on it lol thanks does any one know the torque specs ??
Old Jun 6, 2007 | 06:57 AM
blaze_125's Avatar
Default Re: (BubblegumTate)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BubblegumTate &raquo;</TD></TR><TR><TD CLASS="quote">Then crank on that bolt with an impact wrench . You're not really looking for torque here, you're looking for speed.</TD></TR></TABLE>
Old Jun 6, 2007 | 07:23 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by free99 &raquo;</TD></TR><TR><TD CLASS="quote">thanks for all the help last nite i got in i got some w40 and cleand it out really good the screw and the nut after that i didnt even have to put presure on it lol thanks does any one know the torque specs ??</TD></TR></TABLE>
yeah tight as hell , lol. and use cotter pins.
EK FLY
Mar 18, 2007 02:55 PM
Mavrick
Dec 2, 2006 10:22 PM
EX-JAY
Oct 25, 2004 02:46 PM
C-REX 88
Sep 6, 2004 12:28 AM
speed_racer012
32
Mar 12, 2004 02:58 PM
