Honda S2000 Honda S2000
Ap1 has a small vibration on decelaration?? any suggestions
Old Jun 5, 2007 | 10:23 AM
TypeR#1049's Avatar
Default Ap1 has a small vibration on decelaration?? any suggestions
Well i have owned a few s2k's in the past and recently picked up a 2000 model.. Everything is great except for but at high RPM's in low gears there is a small vibration/roar underneath the car.. Any suggestions.. car drives perfect tho. just noticeable to me.. thanks for the help
Old Jun 5, 2007 | 10:29 AM
LAS2K's Avatar
Default Re: Ap1 has a small vibration on decelaration?? any suggestions (TypeR#1049)
is there a sound that goes along with this vibration?
Old Jun 5, 2007 | 10:36 AM
apSquidFace's Avatar
* B A N N E D *
there is alot of guys that have had problems with the half shafts causing vibration. i personally just had the same problem but it ended up being a bent wheel got a new wheel fixed the problemo.
i would start by chacking the balance of the wheels and the integrity of the tires before assuming that it may be the half shafts.
just my .02 cents.
Old Jun 5, 2007 | 10:48 AM
AnthraxVX's Avatar
Default Re: (apSquidFace)
i am very interested because i JUST bought one yesterday and its having the same problems. let me know. Thanks!
Old Jun 5, 2007 | 12:15 PM
S@nt0s's Avatar
Munkyw3rkz.webs.com
Default Re: (AnthraxVX)
torque your axel nuts down to 220ft. lbs. ensure everything is nice and tight and car has a proper alignment and wheels are balanced
Old Jun 5, 2007 | 12:55 PM
TypeR#1049's Avatar
ITs not the wheels or tires.. they are balanced and good shape.. It only does it when i let off the gas in a low gear and at higher RPM..its vibration and noise yes but not unbarable its just there.. Never does it on acceleration or anything.. whats that half shaft consist of? is that the driveshaft connectors? thanx for input
Old Jun 5, 2007 | 01:19 PM
S@nt0s's Avatar
Munkyw3rkz.webs.com
Default Re: (TypeR#1049)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TypeR#1049 &raquo;</TD></TR><TR><TD CLASS="quote">ITs not the wheels or tires.. they are balanced and good shape.. It only does it when i let off the gas in a low gear and at higher RPM..its vibration and noise yes but not unbarable its just there.. Never does it on acceleration or anything.. whats that half shaft consist of? is that the driveshaft connectors? thanx for input</TD></TR></TABLE>
did u just do the balance??? because just a tiny bit out of spec will get these cars to shake.. tire wear as well....
and ensure that axel nut is torqued down to the 220 specs... they used to be 180 but cause a vibration and a TSB came out to 2220ft lbs
Old Jun 6, 2007 | 06:47 AM
TypeR#1049's Avatar
Im positive its not from the wheels or tires. the vibration is directly under the shifter..???
Old Jun 6, 2007 | 06:54 AM
revhi's Avatar
Clutch disc in 2000 had a tsb with vibration when down shifting.
Old Jun 6, 2007 | 07:19 AM
* B A N N E D *
tranny mount?
Old Jun 6, 2007 | 07:31 AM
S2KILLA's Avatar
From: Yeah IM from Jersey, big wup, wanna fight about, it, USA
possibly a heat shield rattling?
Old Jun 6, 2007 | 08:06 AM
S@nt0s's Avatar
Munkyw3rkz.webs.com
Default Re: (SupersonicBlueGSR)
check the shifter bushing and yes 00's had a clutch issue
Old Jun 6, 2007 | 08:25 AM
AnthraxVX's Avatar
Default Re: (S@nt0s)
well i just bought the 00 and is there a way to fix the "clutch issue" like put a new one in? and if so wut brand etc etc. im used to B series swaps so im sure i can work on ma s2k ez. Thanks for info let me know i also noticed i smell clutch when i run really hard. im surei ts common, just not used to it on my bseries. Thanks!
Old Jun 6, 2007 | 08:27 AM
S@nt0s's Avatar
Munkyw3rkz.webs.com
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AnthraxVX &raquo;</TD></TR><TR><TD CLASS="quote">well i just bought the 00 and is there a way to fix the "clutch issue" like put a new one in? and if so wut brand etc etc. im used to B series swaps so im sure i can work on ma s2k ez. Thanks for info let me know i also noticed i smell clutch when i run really hard. im surei ts common, just not used to it on my bseries. Thanks!</TD></TR></TABLE>
replacing the clutch will do away with the issue... if you arent going FI just get a OEM set up cheaper and holds well....
Old Jun 6, 2007 | 08:29 AM
orangebarius's Avatar
the clutch deceleration buzz. its a tsb. this is from s2ki.com. hope this is what your talking about and helps you.
00-054 20011127 M/T - Buzz/Rattle on Deceleration
http://www.s2ki.com/stor/libra...x.htm
here it is in pdf format:
http://www.s2ki.com/stor/library/TSB/A00-054.pdf
Old Jun 6, 2007 | 08:42 AM
AnthraxVX's Avatar
Default Re: (orangebarius)
thanks, so F1 i find alot on ebay for abotu 300 bux. good then? kool let me know. i will definitely get it done.
Old Jun 6, 2007 | 08:53 AM
TypeR#1049's Avatar
Thanx for all the help guys.. so its a common thing on an 2000-01 S2000..
Old Jun 6, 2007 | 08:57 AM
b20integrapower's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TypeR#1049 &raquo;</TD></TR><TR><TD CLASS="quote">Thanx for all the help guys.. so its a common thing on an 2000-01 S2000.. </TD></TR></TABLE>
Yes it is. I'm VERY suprised it took so long for someone to tell you it was clutch buzz. There are 50 million threads on this issue. Search is always an option next time.
Old Jun 6, 2007 | 09:03 AM
S@nt0s's Avatar
Munkyw3rkz.webs.com
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AnthraxVX &raquo;</TD></TR><TR><TD CLASS="quote">thanks, so F1 i find alot on ebay for abotu 300 bux. good then? kool let me know. i will definitely get it done.</TD></TR></TABLE>
i used one of those on my built SOHC turbo beast.. she made 250whp 200+ ft lbs and held up fine
Old Jun 12, 2007 | 08:46 AM
jdm j's Avatar
Shouldn't it be the exhaust drone?
///Nick
Mar 9, 2012 11:43 AM
duwa
Oct 26, 2011 08:19 AM
Jstaats
Acura TL, RL & ZDX
Oct 31, 2009 07:35 PM
performula
12
Sep 11, 2002 07:49 PM
99civic_exSB
Apr 24, 2002 04:42 PM
