car died for no reason. need help asap!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
we jacked the car up to put a camber kit on and we had to move the fuse box forward but we didn't disconnect anything. when we lowered it and went to crank it up it was dead. help helpl help!!!!!!!!!!!!!!!!!!!!!!!!!!
no we tested it and it was good. all the fuses are good to. we think it might be something with the fuse box under the hood
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxdude »</TD></TR><TR><TD CLASS="quote">its a 96 gunmetal accord yo. not the coupe in the pic</TD></TR></TABLE>
no one would have known since it had not been stated.
what were you doing removing a fuse box for installing a camber kit if I may ask? I was under the impression it did not need to be removed for anything like that.
Have you gone over all the fuses?
Made sure that everything is plugged in and tight?
I would suspect the fuse box to be the culprit
You said you moved it, well there's 4 plugs on the bottom of the fuse box that all go to the harnesses and the ECU.
I would imagine if one of those was even loose the car wouldn't start.
Yeah, bottom part should just pop off and should expose the 4 cables, there may be some tension but it is just some zip ties, I removed my friends when we ran a power wire for his amp.
jdm_addict813
Jun 13, 2011 02:10 PM
ismael02
Sep 17, 2008 07:42 PM
BritBrat
Jul 20, 2007 08:08 AM
