rear main oil seal w/o dropping oil pan
Old Jun 5, 2007 | 05:55 AM
zfreak's Avatar
Default rear main oil seal w/o dropping oil pan
I have the trans out of my '93 del sol Si and was considering replacing the rear main oil seal. The car has 83k miles on it, and the seal is currently not leaking.
Is there a way to replace the seal without dropping the oil pan (the faq I found had the guy pull the oil pan and seal housing). Or, should I leave it alone since it isn't leaking?
Thanks
Mike M.
Old Jun 5, 2007 | 06:01 AM
instructor74's Avatar
Default Re: rear main oil seal w/o dropping oil pan (zfreak)
It is only a matter of time before it will start to leak and no you do not have to drop the oil pan to do it. You should be able to pull the old seal out with a pick or a seal removal tool. just make sure to seat the new seal in the same amount as the original
Old Jun 5, 2007 | 07:03 AM
EG2Driver's Avatar
Default Re: rear main oil seal w/o dropping oil pan (instructor74)
Drill a tiny hole in the seal, the face of it has metal in it. Then take something to pull it out. Its in there really tight, just make sure you don't break whatever you are using so that it falls in the oil pan...
MAKE SURE TO NOTICE HOW FAR IN THE SEAL IS RIGHT NOW AND PUT THE NEW ONE JUST LIKE THAT. Yes, i am yelling. I didn't do that on mine and its leaking, so i gotta take it all apart yet another time.
Old Jun 5, 2007 | 08:02 AM
Crazydave's Avatar
Default Re: rear main oil seal w/o dropping oil pan (DeadEnd9009)
If the seal is not leaking why do you want to replace it?
I would not put a drill in it.
You can easily drill something that you don't want to drill.
I have always dropped the pan, removed the seal housing, installed a new seal into the housing, put the housing back on the block, and then put the pan back on.
Old Jun 5, 2007 | 08:40 AM
Sloshy's Avatar
are you guys talking about transmission pan or motor pan..
i always though you had to take the tranny off to install a new rear main seal so im confuse now...
Old Jun 5, 2007 | 08:42 AM
EG2Driver's Avatar
Default Re: (Sloshy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sloshy &raquo;</TD></TR><TR><TD CLASS="quote">are you guys talking about transmission pan or motor pan..
i always though you had to take the tranny off to install a new rear main seal so im confuse now...</TD></TR></TABLE>
Yea how can you drop the seal and housing without removing the flywheel?
Old Jun 5, 2007 | 09:03 AM
dpetro1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zfreak &raquo;</TD></TR><TR><TD CLASS="quote">I have the trans out of my '93 del sol Si</TD></TR></TABLE>
reading &gt; both of you. lol. i suggest taking the oil pan off as well.
Old Jun 5, 2007 | 09:07 AM
BubblegumTate's Avatar
Default Re: rear main oil seal w/o dropping oil pan (dpetro1)
I've done it on a few cars without dropping the oil pan. I just did it on my Z6 when I replaced the clutch and it hasn't leaked a drop since. Just be careful and make a mental note of how far the old seal is pushed in.
Old Jun 5, 2007 | 09:16 AM
t0p_sh0tta's Avatar
Default Re: rear main oil seal w/o dropping oil pan (BubblegumTate)
If you have access to it, ALWAYS replace the rear main seal. It's a $5 part that is a PITA to change due to the amount of labor involved.
If the tranny is already off, do what the others said and remove the seal with a pick or something of the sort. Pop a new one in, and make sure it doesn't sit above the lip on the housing.
Old Jun 7, 2007 | 10:22 AM
zfreak's Avatar
Default Re: rear main oil seal w/o dropping oil pan (t0p_sh0tta)
Thanks guys. I'm on it this weekend. The new clutch parts came in the mail today.
Old Jun 7, 2007 | 10:30 AM
92redhatch's Avatar
its going to be really hard for you to replace it without taking off the pan. Taking off the pan and putting it back doesnt take longer then 30 minutes. whats the big deal??
Old Jun 7, 2007 | 10:31 AM
92redhatch's Avatar
even when you take off the bracket that the seal is connected to the seal still is a lil hard to pry it off. Dont break you head just take off the pan!
Old Jun 7, 2007 | 10:45 AM
Team RS2's Avatar
Default Re: (92redhatch)
its also a bitch to seat the seal in haha , but if you're doing it professionally expletive dropping the pan thats time right there
Old Jun 7, 2007 | 11:45 AM
sauceja's Avatar
Default Re: (Team RS2)
I have never dropped the pan for a rear seal unless doing a build and already had the pan off.
Drop the pan and go ahead and replace your pickup tube gasket and oil pan gasket while you are there.
Uljima
Jun 3, 2015 06:17 AM
dth0ng69
Sep 22, 2009 11:36 PM
flyjazz
Aug 13, 2009 10:07 PM
jnb426
Jan 9, 2008 04:08 PM
integra3586
Feb 27, 2006 06:51 AM
