my temp gauge going crazy!!!!
Old Jun 4, 2007 | 10:17 PM
supaf1y's Avatar
Default my temp gauge going crazy!!!!
i have a 89 crx and like my temp gauge goes normal but after a while it rises up just under the h line then 10 sec later it goes back down to normal and 3 minutes later it does it all over again and one time i saw my car smoke when i stoped soo i poped the hoood and my radiator cap poped off half way..what do you think is wrong with my car
Old Jun 4, 2007 | 11:35 PM
EF_LSVtec's Avatar
Default Re: my temp gauge going crazy!!!! (supaf1y)
waterpump...
Old Jun 4, 2007 | 11:56 PM
.Manny.'s Avatar
Touching My Member
Default Re: my temp gauge going crazy!!!! (EF_LSVtec)
leaking waterpump. you're probably losing coolant at a small rate and sucking in some air.
Old Jun 5, 2007 | 05:43 PM
supaf1y's Avatar
Default Re: my temp gauge going crazy!!!! (.Manny.)
yah but i asked someone and they were like it couldnt be your water pump because if your water pump was broken there would be water leaking and i dont see any water leaking
Old Jun 5, 2007 | 06:05 PM
DenzComp's Avatar
Next time you go out to start the car....pop the hood, make sure it is full of anti-freeze, leave the rad cap off. Start the car. After it is at normal operating temperature the anti-freeze should be flowing like a river. If it is not...its the water pump.
Old Jun 5, 2007 | 09:53 PM
sneakerfern's Avatar
Default Re: (DenzComp)
thermostat possibly... are ur fans working properly?
Old Jun 6, 2007 | 04:30 AM
Cory man's Avatar
Default Re: (sneakerfern)
If the overheating is occurring while driving you likely have a blown HG. Double check your coolant level and make sure that your fans come on once the car gets to normal operating temp. The D15's had HG issues anyway and a Honda service bulletin was issued revising the HG and torque sequence. hth
Old Jun 7, 2007 | 12:14 AM
supaf1y's Avatar
thanks but i found out the problem i got a leak in the radiator a very small one soo after a while it got low and soo i filled it up all the way it hasnt done that crazy thing yet..
Old Jul 9, 2009 | 06:08 PM
Frederick_Est87's Avatar
I have the same exact symptoms. The thing reads warm, then cold, then warm, and bounces all over (never to the red line though). And I am losing coolant when I checked my reservoir.
One thing though, isn't it dangerous to take that radiator cap off when the engine is running?
bitek
15
Mar 4, 2009 01:07 AM
BacardiBreezer
Jan 17, 2007 05:14 PM
da_33
Nov 30, 2006 08:29 PM
CA6VTEC
Aug 26, 2004 06:37 PM
planeman01
Oct 28, 2002 03:22 PM
