Suspension & Brakes Theory, alignment, spring rates....
Removing Ball joint
Old Jun 4, 2007 | 08:18 PM
JDM_95_LS's Avatar
Default Removing Ball joint
Yeah i was wondering what tool do i use to remove the ball joint from the hub because i'm planning on changing the old one.
Old Jun 6, 2007 | 01:34 PM
WhiteNess's Avatar
Default Re: Removing Ball joint (JDM_95_LS)
There are write ups in the archives....but the easy way to do it is .....
pull the spindle assymbly off the car....bla bla bla..
Get some snap ring pliers and pull the snap ring off the lower part of the ball joint.
Get a 1/2in socket and put it over the bottom part of the ball joint.
HAMMER AWAY
You can press in a new one OR.......
Stick the new ball joint in the freezer for an hour or 2,
Place the new joint in the hole....
HAMMER AWAY...and replace the snap ring into position.
Put the wheel assembly back together...make sure to torque the lugs to the correct specs using only a digital Snap on torque wrench....
There is a Correct way to do this but if you want it done in your driveway this will work just fine.
Oh yea to answer your question...I think auto zone actually rent the tool but you don't really need it to remove a ball joint thats just going in the trash....a few good hits with a hammer and it will pop out.
Hope that helps
WhiteOnRice
Aug 18, 2024 11:11 AM
Dwight Schrute
Apr 20, 2007 03:42 PM
ultraforce77
Jul 15, 2004 02:59 PM
delslow94
Jul 21, 2003 08:53 PM
Flamenco-T
Aug 21, 2002 11:49 PM
