integra front clip on ek?
Old Jun 4, 2007 | 07:38 PM
frankie11's Avatar
Default integra front clip on ek?
can a jdm integra from clip fit on a ek coupe with direct bolt on, or do you need to mod radiator support and or other? sorry if this question has been asked before, I searched. thanks
Old Jun 4, 2007 | 08:14 PM
pc93's Avatar
Default Re: integra front clip on ek? (frankie11)
No, it will not be a direct bolt-on. It requires cutting and welding.
Old Jun 4, 2007 | 08:21 PM
frankie11's Avatar
Default Re: integra front clip on ek? (xxdimsum)
does it require just changing the front radiator support, or do you need to change more?
Old Jun 4, 2007 | 08:30 PM
Libertariat's Avatar
Ek Forever y0!
Front fenders from each car/clip will need to be cut in half and re'welded back together, sanded, bondoed if necessary, and painted.
The radiator support will need to be changed.
Old Jun 4, 2007 | 08:40 PM
frankie11's Avatar
Default Re: integra front clip on ek? (ek forever guy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek forever guy &raquo;</TD></TR><TR><TD CLASS="quote">Front fenders from each car/clip will need to be cut in half and re'welded back together, sanded, bondoed if necessary, and painted.
The radiator support will need to be changed.</TD></TR></TABLE>
is it cut to shorten or add length in the fenders? and how about width for hood?
Old Jun 4, 2007 | 10:28 PM
pkdog167's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by frankie11 &raquo;</TD></TR><TR><TD CLASS="quote">
is it cut to shorten or add length in the fenders? and how about width for hood? </TD></TR></TABLE>
Cutting it half means cut it 50/50?? 50/50 for both fender and weld it up, change the radiator support and everything will bolt on.
Old Jun 5, 2007 | 12:23 PM
NOFX's Avatar
H-T White Ops
Cutting the fenders refers to taking the Civic fenders and the Integra fenders and cutting them from top to bottom in half. So each fender will have a front half and a bottom half.
Save the Civic rear section and the Integra front section. Then weld them together.
Old Jun 5, 2007 | 12:34 PM
JINEIL2EN's Avatar
how to cut..??
any direction..??
Old Jun 5, 2007 | 12:37 PM
Ek Forever y0!
Default Re: (JINEIL2EN)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JINEIL2EN &raquo;</TD></TR><TR><TD CLASS="quote">how to cut..??
any direction..??</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NOFX &raquo;</TD></TR><TR><TD CLASS="quote">Cutting the fenders refers to taking the Civic fenders and the Integra fenders and cutting them from top to bottom in half. So each fender will have a front half and a bottom half.
Save the Civic rear section and the Integra front section. Then weld them together.</TD></TR></TABLE>
Old Jun 5, 2007 | 12:44 PM
NOFX's Avatar
H-T White Ops
Here's an example. On this car though, a 6th gen Civic front is being put on a del Sol.
I wouldn't do this yourself if you haven't before.
Old Jun 6, 2007 | 06:22 PM
frankie11's Avatar
Default Re: (NOFX)
thanks for the info, does the hood need to be altered?
Old Jun 6, 2007 | 10:28 PM
pkdog167's Avatar
Default Re: (frankie11)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by frankie11 &raquo;</TD></TR><TR><TD CLASS="quote">thanks for the info, does the hood need to be altered?</TD></TR></TABLE>
no
powerfulperformance
15
Sep 10, 2019 09:31 PM
racerx510
10
Jul 18, 2013 04:43 PM
777
Dec 1, 2006 10:31 AM
96civich22
May 30, 2006 01:25 PM
VRD^sam
Mar 15, 2006 10:27 PM
