VTEC Not hitting
I dropped a B16a into my 91 rex and am not hitting VTEC. It will run all the way up to rev limiter but doesn't seem to be hitting VTEC. I am running the P30 ecu and me and a friend did a couple hard pulls and then unplugged the solenoid and it felt exactly the same. We cant figure out what the problem might be. If anyone has a idea would love the help and how to fix it. Thanks for the help.
Try taking the vtec solenoid out and see if there's blockage on the screen/gasket..or run a tester on the solenoid lead wire to find out if it's actually getting signal at vtec rpm point. Did you hook up a knock sensor too? I think a P30 requires one..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ef_hatchback »</TD></TR><TR><TD CLASS="quote">take the vtec syleniod and take off the screen and clean it out.</TD></TR></TABLE>
befor all that check your wires again and if you speedo doesnt work check your vehicle speed sensor then maybe after that check your selenoid. 1st time i did a motor it was the wiring and the 2nd time it was the vss cable was broken
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaPartsHero »</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zerothread/1812135</TD></TR></TABLE> x2
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIred91 »</TD></TR><TR><TD CLASS="quote">You mean Vtec is not "working"?....******* vtec does NOT "hit" nor "crack" nor "pop" its for ******* gas mileage for petes sake..... </TD></TR></TABLE> here its for you:
91EF_Si
20
Sep 17, 2007 12:00 PM
