someone with integra repair manual... help me out.
Old Jun 4, 2007 | 06:51 PM
5lugcivic's Avatar
Default someone with integra repair manual... help me out.
i need the torque for the valve cover bolts. also is there a special way of tightening the bolts like tightening head bolts?
Dogginator's Avatar
Daisy... Daisy...
Default Re: someone with integra repair manual... help me out. (5lugcivic)
Download one. Search google for "hondahookup manuals". Join and download.
Old Jun 4, 2007 | 06:53 PM
ForceFed Motorsports's Avatar
Do you even PLEBE R8?
Torque spec is 7 foot lbs if im not mistaken.. i always start from the inside bolts and work my way out switching from front to back.
Ive never torqued valve cover bolts to a spec and have never encountered a problem before. Use a 1/4" drive socket and ratchet, choke up closest to the socket on the handle of the ratchet and tighten by hand. Wont have an issue of over torquing them and should be tight enough to not cause a leak.
Old Jun 4, 2007 | 08:08 PM
5lugcivic's Avatar
Default Re: someone with integra repair manual... help me out. (ForceFed_Motorsports)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ForceFed_Motorsports &raquo;</TD></TR><TR><TD CLASS="quote">Torque spec is 7 foot lbs if im not mistaken.. i always start from the inside bolts and work my way out switching from front to back.
Ive never torqued valve cover bolts to a spec and have never encountered a problem before. Use a 1/4" drive socket and ratchet, choke up closest to the socket on the handle of the ratchet and tighten by hand. Wont have an issue of over torquing them and should be tight enough to not cause a leak.</TD></TR></TABLE>
its either i over torque and stripp something or not equally that spark plugs get flooded with oil. if i stick with torque spec im more likely safer.
Old Jun 4, 2007 | 08:15 PM
Im almost positive the spec is 7lbs but really with a 1/4" drive socket you would really have to put some strength into striping them out. Lotta times i use an air ratchet
Old Jun 4, 2007 | 08:44 PM
1998b18c1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 5lugcivic &raquo;</TD></TR><TR><TD CLASS="quote">
its either i over torque and stripp something or not equally that spark plugs get flooded with oil. if i stick with torque spec im more likely safer. </TD></TR></TABLE>
check the spark plug tube gaskets located on the valve cover---probably old and brittle causing leak. change the v/c gasket and the 4 smaller gaskets. youll be fine im sure....and 7 or 8 lbs should be fine. goodluck
Old Jun 5, 2007 | 12:48 AM
o0oz's Avatar
Default Re: someone with integra repair manual... help me out. (1998b18c1)
it is possible that oil can get into spark plugs if you over tighten your bolts.
Old Jun 5, 2007 | 08:09 AM
5lugcivic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1998b18c1 &raquo;</TD></TR><TR><TD CLASS="quote">
check the spark plug tube gaskets located on the valve cover---probably old and brittle causing leak. change the v/c gasket and the 4 smaller gaskets. youll be fine im sure....and 7 or 8 lbs should be fine. goodluck </TD></TR></TABLE>
even with new ones from dealer still leaks. thats without torque spec though.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by o0oz &raquo;</TD></TR><TR><TD CLASS="quote">
it is possible that oil can get into spark plugs if you over tighten your bolts.: </TD></TR></TABLE>
yea, i belive different torque on each bolt can cause leak.
Modified by 5lugcivic at 12:32 PM 6/9/2007
Hondalover15
Oct 8, 2012 04:12 PM
RACEPAK
Sep 3, 2005 10:14 AM
GRAVEDIGGER
10
Aug 18, 2003 12:13 PM
Phoenix_ITR
Jun 17, 2002 07:10 PM
