Del Sol lights stopped working Help!
If this was an installation from a shop, take it back immediately. If it was your installation, then you need to take your time next time you install/de-install.
Sounds like you have grounded wires. Check the wires connected to the main turn on switch for your parking lights as well as the hazard switch wires. Parking/tail/cluster (back light) are all integrated together. Dome light is often used as the door trigger and will probably be grounded as well.
Test for continuity with the chassis. If you hear a beep, then you have a problem.
Same thing happened to me. I took my radio out and one of the wires had came loose somehow. Cleaned up the install and popped a new fuse in. Fixed.
Sorry, don't have a wiring diagram for a Del Sol, however...
Assuming it's not that diff. from any other Honda/Acura, it sounds like you have more then one problem, [maybe something unplugged].
The hazard and signal lights have separate fuses, even though they both "drive' the same lights, both powers, [hazards, hot at all times, signal lights, hot in run] got through the hazard switch, does the signal lights fuse blow if you use the signal lights?
Park lights and dash lights can be on the same fuse, hot when light switch is on, is there power at the park light fuse when you turn the lights on?
The dome light should also be on a separate fuse from the rest, [hot at all times].
Because there are diff. circuits with a problem, [not working] I would be looking for a loose plug or dash harness ground, [normally found around/on drivers "A" pillar.
The hazard fuse blowing when you turn them on is a short in the hazard/signal light circuit.
94
94Thread
