need help asap
Old Jun 4, 2007 | 03:53 PM
jamescb77's Avatar
Default need help asap
so i just bought a 90 crx si. got it home ran fine everything good. well come to find out that the fuel gauge is way off no big deal. Now today i go to start it and it wont start just turns over with no fire( once it started then died). Add some gas and it start fine. figure this must be the problem drive to the gas station and it won't start after fueling up either just turns over or dies right after starting. finally starts up and drives home(only about .5 miles). I think it might be the fuel pump. what do you guys think? Also how hard is it to put a fuel pump in one of these? thanks jamescb77
Old Jun 4, 2007 | 04:17 PM
ludesrv's Avatar
Change your main relay.
If you noticed, when the car just turns but does not fire, you won't hear a click when your engine light comes on and off on the start up, that's cause your pump ain't priming. The click is from the relay. Change it.
Old Jun 4, 2007 | 04:21 PM
jamescb77's Avatar
ive never heard a click period when the car starts or doesn't start i have never heard a click
Old Jun 4, 2007 | 04:56 PM
mini-me-power's Avatar
You dont hear a click becuase the pump is not priming, check the mail relay and let us know.
Old Jun 4, 2007 | 05:33 PM
JDN169's Avatar
Default Re: (mini-me-power)
+1 on the main relay, the good news is it's cheap and easy to fix.
Old Jun 4, 2007 | 05:48 PM
Snailed EF's Avatar
Default Re: (JDN169)
Main relay mine did the same
Old Jun 4, 2007 | 05:50 PM
jamescb77's Avatar
where can i get a main relay from do normal auto parts stores carry them
Old Jun 4, 2007 | 05:55 PM
JDN169's Avatar
Default Re: (jamescb77)
IIRC they're about $60 from honda (i picked up one from a salvage yard that worked for $10, but that's a gamble and it's still a nearly 20 year old part.
Old Jun 4, 2007 | 06:09 PM
jamescb77's Avatar
so what makes you guys think it the relay and not the pump. im going to go ahead and get a relay but im thinking about upgrading my pump as well
DA9b0y303
29
Aug 21, 2013 03:51 PM
IIDIEIV619
18
Oct 11, 2006 11:54 AM
MJPana
Jul 30, 2006 09:27 AM
rls669
12
Jun 19, 2006 05:46 PM
LilMissCrystal81
Nov 19, 2004 11:26 AM
