Radio Dies then car wont start back up
you might have a dead battery as well. if your battery is really dead you're car will turn off. I know you said your dash lights were on, but you should bring it to autozone or whereever and have it load tested for free
Did you check ALL the fuses? i.e... do you have an aftermarket amplifier? Is it fused? When earthed, that 8AWG or 4AWG wire they tie directly to the battery and then run hap-hazardly through the passenger compartment to the trunk will drain a battery flat in no time and won't blow a single fuse in the fusebox doing it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BubblegumTate »</TD></TR><TR><TD CLASS="quote">Did you check ALL the fuses? i.e... do you have an aftermarket amplifier? Is it fused? When earthed, that 8AWG or 4AWG wire they tie directly to the battery and then run hap-hazardly through the passenger compartment to the trunk will drain a battery flat in no time and won't blow a single fuse in the fusebox doing it.</TD></TR></TABLE>
uhh, say what.
when those get grounded, IF, they get grounded, you'd know it. Lots of sparks, smoke and a blown or melted fuse.
uhh, say what.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sony224422 »</TD></TR><TR><TD CLASS="quote">
uhh, say what.
when those get grounded, IF, they get grounded, you'd know it. Lots of sparks, smoke and a blown or melted fuse.</TD></TR></TABLE>
not necessarily. That is the most likely option, but if your amp failed internally, it could be drawing down the battery but not drawing enough current at once to blow a fuse. Just one more thing to check. Generally, hastily-installed aftermarket options are an invitation to electrical problems.
uhh, say what.
i jump started it and it started but when you take off the positive terminal the car turns off...from what i was told this means the alternator is bad
could water cause the alternator to go bad
i have seen a problem like that when the radio cuts out and the batt is dead
get a multimeter and check ur alternator output
basically , get a new alternator cuz its not putting enough power
GPC91
May 7, 2013 09:06 PM
dc2teg2006
Mar 28, 2009 05:31 PM
braypunt
22
Sep 11, 2005 09:10 AM
