Need help with timing belt install for toda b cams
Old Jun 3, 2002 | 08:53 PM
VTHokie's Avatar
Default Need help with timing belt install for toda b cams
I just purchased a power enterprise timing belt for my car and I'm about to have it installed by a local honda dealership. I was wondering if I should ask them to install it in a specific way. I hear people saying if its too tight it will break, or if its too lose it will break. Will honda be alright with their install, or do I have to tell them to install it a certain way as far as belt tension. I am running toda b cams in my 00 civic si, with toda cam gears, toda valve train, and titanium retainers. Your help would be greatly appreciated, thanks.
Old Jun 3, 2002 | 11:03 PM
t's Avatar
t
Default Re: Need help with timing belt install for toda b cams (VTHokie)
I'm sure the dealership will like you to tell them how to do their job.
It will be alright, They can put on a timing belt.
Old Jun 3, 2002 | 11:06 PM
Reid's Avatar
Global Moderator
Default Re: Need help with timing belt install for toda b cams (t)
Are you sure you want to have them do the work?
Keep in mind they could do a halfass, shoddy job then blame the failure of your motor on the aftermarket parts used.
Old Jun 4, 2002 | 12:08 AM
bearingburner's Avatar
you should do it your self it is not as hard as it seems it took me about one and a hlf hours to install mine
Old Jun 4, 2002 | 12:09 AM
Default Re: Need help with timing belt install for toda b cams (bearingburner)
just be sure to readjust the tensioner after 3000 miles. the belt does have a little stretch after a while
Old Jun 4, 2002 | 12:11 AM
ITRinEJ1's Avatar
no special way. a timing belt is a timing belt
Old Jun 4, 2002 | 01:12 AM
C-speed's Avatar
Default Re: Need help with timing belt install for toda b cams (ITRinEJ1)
Merry xmas:
http://www.c-speedracing.com/howto/t...elt/tbelt.html
Old Jun 4, 2002 | 01:18 AM
Art Vandeleigh's Avatar
not to be an ***, but if a timing belt is a timing belt, why buy a PE belt. i have never seen one, but have done more then my share of T belt jobs and i think that they are all the same, but again i have never seen a PE belt so....
Old Jun 4, 2002 | 02:17 AM
VTHokie's Avatar
Cool, yeah i trust the dealership i go to, they always do a good job on my car. Thanks for the info guys.
Eric
Old Jun 4, 2002 | 10:13 AM
Drag R's Avatar
why do you people love the honda dealership? what happens if they put it too tight, or too tight, and u end up snapping the belt again, and u bend ur valves. is honda gonna replace or fix those aftermeket items. Thats just my question...
nick
Old Jun 4, 2002 | 11:28 AM
Jason's Avatar
Default Re: Need help with timing belt install for toda b cams (cali-r)
A timing belt IS a timing belt...plain and simple...
WHY buy a PE belt, you ask? Because its stronger...it's not really a hard concept. They all go on the same is what he meant by a "timing belt is a timing belt"
B18Redline
Dec 23, 2003 12:06 AM
integrasi
Sep 21, 2003 09:30 PM
DA MUGEN 1
Mar 29, 2003 07:14 AM
Carnage24
Jan 2, 2003 02:12 PM
VTHokie
Jul 8, 2002 01:06 AM
