Seafoam Today
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Smoke4206 »</TD></TR><TR><TD CLASS="quote">HIT it hard and smoke the whole block out!!
no you dont wanna do that.
I wouldn't use this, my old integra started burning oil after this.
put it on the gas tank better.
</TD></TR></TABLE>no you dont wanna do that.
Munkyw3rkz.webs.com
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SilverDc2 »</TD></TR><TR><TD CLASS="quote">
put it on the gas tank better.</TD></TR></TABLE>
it did that because it cleaned out your motor so good that the carbon build up was helping keep things sealed up
.. change your plugs after seafoaming your motor
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by S@nt0s »</TD></TR><TR><TD CLASS="quote">
.. change your plugs after seafoaming your motor</TD></TR></TABLE>
yup change your spark plugs., and i only did 1/3 tank, 1/3 injected,
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by S@nt0s »</TD></TR><TR><TD CLASS="quote">i personally dont do seaform, i rather keep the build up to bump the comp up.. hehehe
as long as the motor is taken care of things stay clean!
agreed. it's not worth the trouble. do regular oil changes and run synthetic oil and avoid arco gas, you'll be fine.
</TD></TR></TABLE>agreed. it's not worth the trouble. do regular oil changes and run synthetic oil and avoid arco gas, you'll be fine.
