Welding does it matter?
Old Jun 4, 2007 | 03:23 AM
SilverWarrior's Avatar
Default Welding does it matter?
Does it matter what type of flame they are using to weld my piping ?
thx!
Old Jun 4, 2007 | 06:42 AM
hybridmoments's Avatar
Default Re: Welding does it matter? (Naked)
as long as the flame is HOT and you don't have any leaks it doesn't matter too much.
Old Jun 4, 2007 | 07:30 AM
dsnyder305's Avatar
The fuckyeah it does. There's TIG welders, MIG welders, heliarcs (but those are usually only for aluminum), and who does the welding also has alot to do with the end result. Good welders are hard to come by, and a good welder has more to do with the job outcome than the type of welding tool they use.
Old Jun 4, 2007 | 08:14 AM
ManBearPig4silly's Avatar
um yeah. what are the welding?
Old Jun 4, 2007 | 10:01 AM
Default Re: Welding does it matter? (dsnyder305)
oxy acetylene, Arc, Mig, Tig
it will all work on mild steel, stainless. if anyone says it won't then they are full of ****. though for aluminum it is easiest with TIG in my opinion. though a MIG with a Spool Gun works. just not as much control with that.
though flange warpage is another issue all together depending on which of the processes you use.
f90w
Welding / Fabrication
Dec 12, 2008 10:17 PM
atg1290
Aug 13, 2006 11:47 AM
pubestripe
Jan 28, 2005 08:18 AM
B6tPoweredMx3
Sep 24, 2004 07:58 AM
_Shadow_
Mar 19, 2002 12:05 PM
