no vtec pressure switch
Old Jun 3, 2007 | 09:42 PM
Eli Mac 67's Avatar
Default no vtec pressure switch
got a jdm with no vtec pressure switch, i tryed grounding out the blu/blk wire and re-settin the ecu and still no vtec, and the i tryed puttin the vtec solenoid wire to the + post and it clicked so its works....any ideals on what else to do
Old Jun 4, 2007 | 09:41 AM
Relic1's Avatar
At the ECU, connect the VTEC pressure switch wire to the VTEC solinoid wire.
Old Jun 4, 2007 | 06:18 PM
Eli Mac 67's Avatar
Default Re: (Relic1)
i just tryed and still vtec is not kickin in
Old Jun 5, 2007 | 07:03 AM
Relic1's Avatar
just a shot in the dark, is the CEL on?
Old Jun 5, 2007 | 02:41 PM
Eli Mac 67's Avatar
ya the lights on, not sure what code it is yet workin this week, on monday goin to the shop
Old Jun 5, 2007 | 07:46 PM
Eli Mac 67's Avatar
Default Re: (Eli Mac 67)
If ya got any other things to try it would help lots
Old Jun 6, 2007 | 11:42 AM
gibsanez's Avatar
Check the light yourself.
Old Jun 6, 2007 | 03:23 PM
builthatch's Avatar
MiG-21 superfan
Default Re: (gibsanez)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gibsanez &raquo;</TD></TR><TR><TD CLASS="quote">Check the light yourself.</TD></TR></TABLE>
yeah, exactly...
Old Jun 6, 2007 | 03:50 PM
Eli Mac 67's Avatar
Default Re: (builthatch)
... 7 fast blinks pause then 2 short
7=Throttle Position (TP sensor)
2=O2B - Oxygen sensor #2
right?
Old Jun 6, 2007 | 04:10 PM
Eli Mac 67's Avatar
oh...reading wrong i guess or would it be code 72 cylinder no.2 misfire????
Old Jun 6, 2007 | 04:44 PM
builthatch's Avatar
MiG-21 superfan
nah i think you had it right the first time....
Old Jun 6, 2007 | 05:01 PM
Eli Mac 67's Avatar
ya i was hopein so, but checked plugs anyway, looked all good working, unpluged the injecton when car was running and it did the same as the other cyinders sounds like it was goin to die...how would i go about fixing the throttle position sensor?? or would that be comin on because of the 02? the car starts fine then about 10 seconds after it idles up a little and thats when the cel comes on, it idles up cuz its tryin to get more to the sensor right?
Swap'DShuttle
10
Aug 12, 2012 02:35 AM
Bump
Sep 28, 2005 04:12 PM
sharkcohen
Mar 11, 2005 07:55 AM
Gonzo_SiR
Apr 12, 2004 08:28 PM
RS Design
Apr 10, 2004 11:16 PM
