D15B Timing Belt?
I am doing the timing belt on my jdm D15B. I bought the D16z6 belt but it seems to have a little to much slack. I read that the D15Z1 (VX) timing belt will work?. (Read it on D-SERIES.ORG)
Or is there a proper belt for the D15b?
The deck height is different.
I'm no d-hybrid pro, but when you have a mini-me I'm 99% positive you use the timing belt that was used on the doner motor of the head installed.
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bejita »</TD></TR><TR><TD CLASS="quote">The VX timming belt is the proper belt.
The D16 belt has too many teeth. Thats why it's a bit loose.</TD></TR></TABLE>
I am also in the market for a new belt, I know he said D15Z1 belt works great, but what other options are there? ok, so u guys said us D15B Vtec guys cant use the 1.6L belts, so we can ONLY use the 1.5L belts as long as there VTEC,RIght?
So I guess i need to find out what d15 motors were VTEC....
if its the jdm D15b u have to use the vx belt!!! here is a helpful link to all the other parts for that motor
http://www.d-series.org/forums...32597
I will be doing a b7/D15B vtec mini me and i want to know what timing belt is the correct one, I've read that the D15b vtec head is almost the same as the Z6 head so should i use the z6 timing belt?
