Stripped Timing Belt Tensioner -- HELP!!
I put a new timing belt on my car. when i went to tighten the timing belt tensioner, the bolt went in almost all the way but now it just spins and doesnt tight down. i pulled the bolt out and sure enough the threads from thebolt hole in the block came out on the bolt. my friend suggested a heli coil but that would mean i have to pull the motor i just put in to drill out the bolt hole. is there an easier way to rethread the hole or am i F*ed?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbo93da »</TD></TR><TR><TD CLASS="quote">well you are pretty fucked but
you can try a helicoil but dont expect it to hold forever</TD></TR></TABLE>
yea that sums it up, i would try the helicoil also and if not then tap it to the next size up and use a bigger bolt, but i dont know if that will work inside the tentioner.
heli coil is ur only option really. i had a similiar problem with an oddysey. i was able to unbolt the motor and raise the vehicle up high enough to get a drill in there. u might not have to actually remove the engine.
good luck
good luck
alright thanks guys i think i'm gonna try to just take the driver side, front, and back motor mounts out and tilt the motor down and hopefully there will be enough room to get a drill up there.
Same thing for me on a Honda 3.0 VTEC should apply on 3.2 and 3.5 I think but anyway if you look at the bolt hole on the back side of the motor it's a lip I drilled all the way through and put a nut on the back side of it there's just enough room for that holds great put some loctite on it I've been driving my car over a year like that
WaryDriver
27
Oct 7, 2015 08:42 PM
chope045
11
Aug 15, 2011 11:16 PM
methos713
May 5, 2008 12:29 AM
