if u put a b16a2 in q 98 civic ex do u have to change the wiring harness
if u put a b16a2 in q 98 civic ex do u have to change the wiring harness or just jump the ecu from obd 2 to obd 1
Cool Cool Island Breezes. BOY-EE
you just jump the ECU. pretty much everything else will plug in. You have an ex so you're lucky enough to have VTEC, and knock allready wired in. You will have to switch the injector plugs, and maybe a few manifold plugs like the intake temp. sensor plug. Very easy.
bunnyx
May 8, 2008 11:46 AM
