High output alternator for the prelude?
Old Jun 3, 2007 | 03:34 PM
Obelisk6800's Avatar
Default High output alternator for the prelude?
I'm new here but not to cars. I'm normally post on SoCalPrelude.com but I do browse honda-tech every now and them. Anyway, I wanted to know if anyone can recommend a high-output alternator for the Prelude. I drive a blue manual 5th gen with a lot of electronics. I have about a 1600watt rms audio system, a gaming computer with a 750watt power inverter, PS2, and a few other things too. All this is running off my stock alternator right now and an Optima yellow top (relocated to the trunk). I plan to get a second yellow top eventually but I don't think the stock alternator will be sufficient. So, does anyone know of a bolt on or a custom alternator I can get? I also removed my powersteering system so I have more room in the alternator area.
Old Jun 3, 2007 | 03:52 PM
Prudz_lude's Avatar
Default Re: High output alternator for the prelude? (Obelisk6800)
msd sells some high output ones. they are expensive as hell but are all chrome and shiney
Old Jun 3, 2007 | 04:12 PM
mattsnooz's Avatar
Default Re: High output alternator for the prelude? (Prudz_lude)
I would figure out first your amperage drawn first. stock 4th gen lude's alternator's are good up to 90-95 amps of consistant draw. but only need a fraction or so for functioning components leaving still a bit for you to use freely. Your 1600 watt stereo draws a bit when cranked and pumping out the bass, but i'd still say you'd be okay with stock alternator. Though stock is probably more money than a pretty good aftermarket one anyway! I think after stock your looking at around 150 amp alternators, but then you might have to do rewires to handle the higher currents.
do some searching on stock alternator wires/batteries to make sure they can handle 60 more probable amps.
http://www.4alterstart.com/highoutputalternators/
Old Jun 3, 2007 | 05:40 PM
Giant_Bean's Avatar
Default Re: High output alternator for the prelude? (mattsnooz)
Bosch makes a 180 amp alt, but it is ridiculously expensive.
Old Jun 4, 2007 | 01:52 AM
well, the MSD alternators looks like they cost around $400 and i'm assuming that I need to make a custom bracket or some sort to get it to fit. I couldn't find the bosch one though. Any more ideas?
Old Jun 4, 2007 | 08:26 AM
Hawkze_2.3's Avatar
Default Re: (Obelisk6800)
Powermaster makes high output alternators...
Old Jun 4, 2007 | 09:34 AM
jaywoodz's Avatar
Default Re: (Hawkze_2.3)
power steering off? I'd die without it. :/ I run a laptop in my car too, and I use an iGo adapter, and it works great.
Old Jun 4, 2007 | 10:05 AM
AznBlueBoy's Avatar
Default Re: (jaywoodz)
just bring your stock one to a shop to have it rewound for higher output
model x
Oct 12, 2005 04:48 PM
Robb
Aug 6, 2002 05:36 AM
