load detector fuse
Old Jun 3, 2007 | 11:22 AM
_skitzo_'s Avatar
Default load detector fuse
Hey guys, what I thought was my alternator (just changed it) something else seems to be blowing my load detector fuse.
I put a fuse in and with a min or two..it blows again.
Does anyone have an idea why might this be happending?
I also dont have any amps in my car...
Thanks
Old Jun 3, 2007 | 03:36 PM
_skitzo_'s Avatar
Default Re: load detector fuse (_skitzo_)
TTT
No one has an idea why?
Old Jun 3, 2007 | 03:46 PM
EE_Chris's Avatar
Because an amount of current in excess of what the fuse was rated for is trying to be pulled through it. A short in the wiring generally causes the fuse to blow instantly. It sounds like a device that's powered off that fuse is taking a **** after a min or two.
Old Jun 3, 2007 | 03:57 PM
rc2o6's Avatar
quick question. where is there load detector fuse located? thanks
Old Jun 3, 2007 | 08:16 PM
slowcivic2k's Avatar
Default Re: load detector fuse (rc2o6)
It falls under the alt/sp sensor fuse. I had this fuse blow many times, and it ended up being a second o2 sensor harness heater wire shorting to ground, because I no longer have a use for it. (OBD1 B16A)
Check any wiring you may have done in the past, thats where I fould my problem after accusing my alternator.
LUDE21
May 31, 2007 01:52 PM
Sic_DA_Nine
Jan 8, 2007 09:54 AM
Sic_DA_Nine
Audio / Security / Video
Jan 7, 2007 11:04 AM
Cyrus4g63
Oct 9, 2006 08:40 PM
