shift linkage or transmission
Old Jun 3, 2007 | 08:57 AM
vandersmissenc's Avatar
Default shift linkage or transmission
last night i was driving and i heard something make a noise like *clink* when i shifted from first to second. From that point on when i was driving it wouldn't move in first, it would start to go in second and then it would pick up. Although, i smelt burning clutch. When i got home i looked in the engine bay and i pushed the shift linkage into the transmission and it made a *clink* (i thought that was just me putting it into gear) But, now it will drive in all gears, the problem is that anytime i get over 4-5k the car is revving but there is no connection between the gears because i don't have any acceleration. My dad seems to think when i pushed the shift linkage in it was misaligned and he said to take it to a shop. What does it sound like to you guys. TIA
Old Jun 3, 2007 | 09:28 AM
Default Re: shift linkage or transmission (vandersmissenc)
bump
could the clutch have slipped ?
Old Jun 3, 2007 | 11:47 AM
Magik123's Avatar
as true with any problem start w/ the easy first... adjusting the shift linkage shouldnt be 2 bad even if u take it to a shop and have em do it for ya... When u start taking the gears out the trans and replacing forks and gear clusters is when it gets more expensive... usually cheaper do get a remaned trans. (it does sound more like a trans problem tho difficulty shifting and slippin out of gears prob linkage but when ur searching for gears or not gettin any response sychro usually the prob check gear lube for metal shards)
Old Jun 3, 2007 | 11:59 AM
hatchling37's Avatar
You're roasting clutch? Do you have any fluid seepage? Are you losing tranny fluid and when was the last time you checked the level?
I'm starting to think you have bad seals or something and you're clutch is saturated with oil. If your fluid is too low, I would think that would cause problems trying to shift. If you've got to force the shifter, something is wrong.
Old Jun 4, 2007 | 07:44 PM
Default Re: shift linkage or transmission (hatchling37)
turns out the pressure plate was cracked in half .... none of us are sure how that happened but that's what it was so ireplaced with an exedy clutch kit and now it pulls HARD ... i like it. thanks guys
Mike Chartrand
Transmission & Drivetrain
Jul 6, 2017 07:32 AM
Alicali
Nov 30, 2016 09:23 AM
ki11a8ee
Apr 6, 2010 11:54 PM
92hatchboi
Oct 22, 2007 06:13 PM
