Who knows the difference between B18A and B18B??
Old Jun 3, 2002 | 06:40 PM
johnlsturbo's Avatar
Default Who knows the difference between B18A and B18B??
Is the b18a (old skool) good to use with a 94 civic hb? meaning the engine only since, I do have a type-r tranny? Will ALL the Mounts line up?
Old Jun 4, 2002 | 07:42 AM
CTRwannaB's Avatar
Default Re: Who knows the difference between B18A and B18B?? (johnlsturbo)
it should bolt rite up since u just using the long block.
the only notcable differance i can see is the intake manifold...besides the cable tranny.
Old Jun 4, 2002 | 08:39 AM
White Lightnin's Avatar
Default Re: Who knows the difference between B18A and B18B?? (CTRwannaB)
The heads are different. b18b gives better flow= more power
Old Jun 4, 2002 | 03:49 PM
erniecars's Avatar
Default Re: Who knows the difference between B18A and B18B?? (White Lightnin)
a b18a will work but its kindof old so if you want it in good shape it might need a rebuild or whatever depending on mileage. Also, a b18a must have been from 90-93, probably 92-93 if you are going to stick with obd-1 but thats still too old for your car and it would be illegal in CA where you are located. Still those things are not hard to get by.
Old Jun 4, 2002 | 10:43 PM
thanx guys...this will help me pursue my ls/vtec build up. I was just worried about the drivers side lower mount not bolting up since the integra 90-93 doesn't use or have one.
hotinteggy
Feb 28, 2007 12:37 PM
latinf86
Sep 5, 2006 02:04 AM
hgw84
Mar 7, 2006 03:03 PM
Tammy_EP3
Oct 16, 2003 02:12 PM
CRXSleeper
17
Sep 17, 2002 06:42 PM
