power gains
Old Jun 2, 2007 | 08:06 PM
sleepery7's Avatar
Default power gains
does anyone wat kind of power gains i would get from switching a d16z6 head to a d16y7 motor, cause my friend whos in to cumstangs is bitching saying im gana get nothing. also can i take the stock vtech control from the z6 or would i have to get a aftermafket control and wireing?
Old Jun 2, 2007 | 08:20 PM
Libertariat's Avatar
Ek Forever y0!
Default Re: power gains (delsolmankiller)
You'll have less power actually, about 30 less hp at the crank.
Old Jun 2, 2007 | 08:24 PM
sleepery7's Avatar
Default Re: power gains (ek forever guy)
damn r you serrius
Old Jun 2, 2007 | 08:27 PM
Ek Forever y0!
No, I lied to you. YES, I'm serious.
Honda D engine
From Wikipedia, the free encyclopedia
Jump to: navigation, search
This article or section does not cite any references or sources.
Please help improve this article by adding citations to reliable sources. (help, get involved!)
Any material not supported by sources may be challenged and removed at any time.
(See WP:BRD for suggestions how to do this constructively.) This article has been tagged since September 2006.
D16Z6 Engine Lightly Customized.The Honda D engine is a family of inline 4-cylinder engines used in a variety of compact Honda models, most commonly the Honda Civic, but also the CRX, Logo, Stream, and first-generation Integra. It ranges between 1.2 and 1.7 liters in displacement and is available in SOHC and DOHC versions. Some SOHC models are equipped with VTEC. Power range started from 62 hp (currently the smallest engine uses a 1.4 L 90 hp engine, code D14A4) to 135 hp. The D-series was introduced in 1984 and ended production in 2005 with the introduction of the 8th generation Honda Civic.
Contents [hide]
1 Hot-rodding the D series
2 Mini-Me
3 Engine Specs
3.1 D13 Series Engines (1.3 Litre)
3.1.1 D13B1
3.1.2 D13B2
3.2 D14 Series Engines (1.4 Litre)
3.2.1 D14A1
3.2.2 D14A2
3.3 D15 Series Engines (1.5 Liters)
3.3.1 D15A2
3.3.2 D15A3
3.3.3 D15B
3.3.4 D15B (with 3 stage VTEC)
3.3.5 D15B1
3.3.6 D15B2
3.3.7 D15B6
3.3.8 D15B7
3.3.9 D15B8
3.3.10 D15Z1
3.3.11 D15Z4
3.4 D16 Series Engines (1.6 Liters)
3.4.1 D16A1
3.4.2 D16A3
3.4.3 D16A6
3.4.4 D16A7
3.4.5 D16A8
3.4.6 D16A9
3.4.7 D16Y5
3.4.8 D16Y7
3.4.9 D16Y8
3.4.10 D16Z6
3.5 D17 Series Engines (1.7 Liters)
3.5.1 D17A1
3.5.2 D17A2
3.5.3 D17A6
3.5.4 D17A7
4 ZC (similar to D15Z4, D16A1, D16A3, D16A6, D16A8 and D16A9 engines)
5 External links
[edit] Hot-rodding the D series
Although the availability of used D-series engines at low prices makes it somewhat popular among those who modify it for high performance (as well as a popular item for swapping into earlier or less powerful Civics for an instant and trouble free power upgrade), the unmodified engine won't survive quite as much power enhancement by use of such external modifications as turbochargers, superchargers, or nitrous oxide as the more powerful, somewhat more robust, and more expensive B-series in the Integra.
The Achilles heel of the D-series seems to be its connecting rods, which will withstand a power increase up to a certain point but will break if that limit is exceeded. Generally, a D-series motor can handle up to about 220 bhp, as long as care is taken to avoid detonation through careful spark and fuel management. Of course, the connecting rods, pistons, and other internal parts can be replaced with more durable aftermarket parts that can handle more power, but many choose to swap to a B-series motor to avoid the potential risks of engine building. In all practicality though, the B series is much more expensive to swap in than most D-series engine builds with forced induction or nitrous combined. The D-series also has the ability to swap some parts between different motors and among some B-series parts as well.
When employing forced induction on a D16, at a minimum the stock hypereutectic pistons should be replaced as well as the connecting rods if the commonly used "stock parts" limit of 220 HP is to be exceeded, although it should be noted that the D series crankshaft in particular has been found to reliably handle up to 600 HP.
High compression OEM pistons are a quick way to gain horsepower in a naturally aspirated motor. All D-series motors run the same bore (75 mm), however most factory motor variations (i.e. d16a1, d15b7, d16y7) have used a different piston compression height as well as a different dome or dish. In general, the older D motors have a higher compression height and a larger combustion chamber which create around a 9.1:1 - 9.4:1 compression ratio from the factory. The newer variants have slightly lower compression height combined with a much smaller combustion chamber to create a compression ratio of 9.4:1 - 9.9:1. Now if you combine an older d16 motor's piston with that of a newer d16 head you can end up with a compression ratio of about 10.7:1 with no other work (i.e. D16A1 piston, D16A6 head). There are a few websites that have compression ratio calculators for Honda motors.
·D15 has smaller main bearing diameters. D16 and D17 cranks share the same size main bearing diameters.
·D16 and D17 rods all have the same major dimensions. The D15 rod is shorter (in general) and has a smaller bearing size, although the wrist pin bore is the same.
·D15Z1 and D15B motors have a rod that is the same length as a D16. Other than the rod length, the rest of the bottom end is D15 spec (i.e. rod and crank bearings). D15B has D16 sized rod journals. D15B uses the same p28 rods that the D16z6 does. All other D15s have smaller rod journals.
·The B18A/B Rod has the same bearing bore as a D16. It is 0.044" wider, so the sides of the "big end" of the rod have to be shaved down for use in a D16/17. The wrist pin bore is larger so a conventional D15/16/17 piston can only be used if the stock "small end" bushing in the rod is replaced with one of the proper size. These affordable rods are generally considered to be able to handle up to 300 HP.
·There is a D16 motor that runs on compressed natural gas (96-98 Civic GX). The pistons from that motor have a 12.5:1 CR. The wrist pin bore in the 98-00 D16B5 is 21 mm, like the B18B rod. D17A7 01-05 Civic GX uses 19 mm wrist pins.
·Interestingly enough, the Suzuki Vitara has a 75mm bore as well, so engine builders have occasionally used these pistons in the D16 motor. These pistons are commonly referred to as Vitaras, and they provide an 8.5:1 compression ratio, and thicker ring lands. Lowering the stock compression ratio lowers compression heat, which raises the detonation thresh-hold and is useful when employing forced induction.
D-series.org General D-series Informational Forum
Zeal Autowerks Compression Calculators for Popular Honda Motors & Horsepower Estimate Calculator
Compression Calculator and D-series Piston Information
Turbo D16
Sohc Honda
[edit] Mini-Me
One of the most popular and effective methods of achieving greater power from a D-series motor is replacing the cylinder head with one from a more powerful D-series motor. This is usually done between D16A6 and D16Z6 or D16Y7 and D16Y8 engines. The Z6 and Y8 heads are VTEC (Variable Valve Timing and Lift Electronic Control) equipped, and increase horsepower significantly over stock levels. This operation is known as a "Mini Me" or partial swap. Mini Me's are popular because they offer a substantial performance upgrade by adding VTEC to the motor at a relatively low cost.
[edit] Engine Specs
[edit] D13 Series Engines (1.3 Litre)
[edit] D13B1
Found in:
1987-1991 Honda Civic DX (European Market)
Displacement : 1343 cm3
Bore and Stroke : 75 mm X 76 mm
Compression : 9.5:1
Power, Torque : n/s (Not stated in Owners Manual)
Valvetrain : SOHC, 4 valves per cylinder
Fuel Control : Single Carburettor
[edit] D13B2
Found in:
1992-1995 Honda Civic DX (European Market)
Compression : 9:1
Power, Torque : 75 hp @ 5300 rpm
Fuel Control : Carburettor
[edit] D14 Series Engines (1.4 Litre)
[edit] D14A1
Found in:
1987-1991 Honda Civic GL and 1990 CRX (European Market)
Displacement : 1396 cm3
Bore and Stroke : 75 mm X 79 mm
Compression : 9.3:1
Power, Torque : 90 ps (90 bhp) @ 6300 rpm, 112Nm @ 4500 rpm
Fuel Control : Dual Carburettor
[edit] D14A2
Found in:
1995-1996 Honda Civic MA8 (European Market)
Bore and Stroke : 75.0 mm X 79.0 mm
Compression : 9.2:1
Power, Torque : 66kW @ 6100 rpm, 117Nm @ 5000 rpm
Fuel Control : Multi-point fuel Injection, PGM-FI
[edit] D15 Series Engines (1.5 Liters)
[edit] D15A2
Found in:
1984-1987 Honda CRX DX
1984-1987 Honda Civic (JDM)
Displacement : 1488 cm3
Bore and Stroke : 74 mm X 86.5 mm
Compression : 9.6:1
Power : 76 hp @ 5500 rpm & 84 ft·lb/f @ 3500 rpm
Valvetrain : SOHC 3 valves + 1 auxiliary valve for each cylinder
Fuel Control : Carbureted, CVCC
[edit] D15A3
Found in:
1985-1987 Honda CRX Si and 1987 Civic Si (AU/NZ)
Compression : 8.7:1
Power : 91 hp @ 5500 rpm & 93 ft·lbf @ 4500 rpm
Valvetrain : SOHC, 3 valves/cylinder
Fuel Control : Fuel Injected, Multi-point PGM-FI
[edit] D15B
VTEC
Found in:
1991-1999 Honda Civic VTi EG4 (Japanese Market)
Displacement : 1493 cm3
Bore and Stroke : 75 mm X 84.5 mm
Rod Length : 137 mm
Compression : 9.6:1
Power : 130 hp @ 6800 rpm & 102 ft·lbf @ 5200 rpm
Valvetrain : SOHC VTEC
Fuel Control : OBD-1 MPFI
[edit] D15B (with 3 stage VTEC)
3-stage VTEC
Found in:
1996-1999 Honda Civic VTi EK3 and Fagio Vi
Rod Length : 137 mm
Compression : 9.6:1
Fuel Control : OBD-2 MPFI
[edit] D15B1
(Same as the D15B2 engine, but with a mild camshaft, and a restrictor plate between the throttle body and intake header)
Found in:
1988-1991 Honda Civic Hatchback
Bore and stroke : 75 mm X 84.5 mm
Compression : 9.2:1
Power : 70 hp @ 5500 rpm & 83 ft·lbf @ 3000 rpm
Valvetrain : SOHC (4 valves per cylinder)
Fuel Control : OBD-O DPFI
[edit] D15B2
Found in:
1988-1991 Honda Civic DX/DLX
1992-1995 Honda Civic LSi Hatch/Saloon (European Market)
Compression : 9.2:1
Power : 90 hp @ 6000 rpm & 119 Nm @ 4500 rpm
[edit] D15B6
Found in:
1988-1991 Honda CRX HF
Compression : 9.1:1
Power : 62 hp(88-89) 70 hp(90-91)@ 4500 & 83 ft·lbf @ 3000 rpm
Valvetrain : SOHC (2 valves per cylinder)
Fuel Control : OBD-0 MPFI
[edit] D15B7
Found in:
1992-1995 Honda Civic CX (Canadian model)
1992-1995 Honda Civic DX/LX
1993-1995 Honda Civic del Sol S
1992-1995 Honda Civic LSi Coupe (European Market)
Compression : 9.2:1
Power : 102 hp @ 5900 rpm & 98 ft·lbf @ 5000 rpm
[edit] D15B8
Found in:
1992-1995 Honda Civic CX (U.S. model)
Compression : 9.1:1
Power : 70 hp @ 4500 rpm & 83 ft·lbf @ 3000 rpm
[edit] D15Z1
VTEC-E
Found in:
1992-1995 Honda Civic VX
1992-1995 Honda Civic VEi (European Market)
Rod Length : 137 mm
Compression : 9.3:1
Power : 92 hp @ 5500 rpm & 97 ft·lbf @ 4500 rpm
VTEC Switchover : 2500 rpm
Valvetrain : SOHC VTEC-E (4 valves per cylinder)
[edit] D15Z4
Found in:
1996-1998 Civic LX
Power : 114 hp @ 6500 rpm
Torque (ft·lb@rpm): 99 (136 N·m) @ 5,100 rpm
Valvetrain : SOHC
[edit] D16 Series Engines (1.6 Liters)
[edit] D16A1
Found in:
1986-89 Acura Integra (USA)
Displacement : 1590 cm3
Bore and Stroke : 75 mm X 90 mm
1986-1987 Compression : 9.3:1 1988-1989 Compression : 9.5: 1
1986-1987 Power : 113 hp @ 6250 rpm 1988-1989 Power : 118 hp @ 6500 rpm
1986-1987 Torque : 99 ft.lb @ 5500 rpm 1988-1989 Torque: 103 ft.lb @ 5500 rpm
Valvetrain : DOHC
[edit] D16A3
Found in:
1986-89 Acura Integra (Australia)
Compression : 9.5:1
Power : 118 hp @ 6500 rpm & 103 ft·lbf @ 5500 rpm
Valvetrain : DOHC
[edit] D16A6
Found in:
1988-1991 Honda Civic Si, CRX Si, Civic Wagon RT4WD
1988-1995 Honda Civic Shuttle RT4WD (UK/Europe/Asia/AU/NZ)
1989-1996 Rover 216/416 GTI (UK/Europe)
Compression : 9.1:1
Power : 108 hp @ 6000 rpm & 100 ft·lbf @ 5000 rpm, redline 6800 rpm (USA)
Note: 1988 engines were 105 hp, MY89-91 hp was increased to 108
Valvetrain : SOHC
Fuel Control : OBD-0 Multi-point PGM-FI
Head Code : PM3
[edit] D16A7
Basically a D16A6 that came without a catalytic converter, like the European version of the D16A6.
Found in:
92-95 Models in South Africa
Civic Shuttle 4th gen ( D16A7 / EE4 )
Compression : 9.6:1
Power : 115 hp & 102 ft·lb
Valvetrain : SOHC
Still researching information on this engine Green 91
[edit] D16A8
Found in:
1988-1991 Civic/CRX/Concerto (UK/Europe/Australia)
1990-1995 Rover 216/416 (UK/Europe)
Compression : 9.5:1
Power : 122 hp @ 6800 rpm & 108 ft·lbf @ 5700 rpm
Valvetrain : DOHC
Piston Code: PM7
[edit] D16A9
Found in:
1988-1991 Civic/CRX/Concerto (UK/Europe)
1992-1995 Civic Si (Peruvian version)
1992-1995 Civic GTi
Compression : 9.5:1
Power : 130 hp @ 6800 rpm & 108 ft·lbf @ 5700 rpm
Valvetrain : DOHC
[edit] D16Y5
VTEC-E
Found in:
1996-2000 Honda Civic HX
1996 Honda Civic EX(sedan peruvian version)
Compression : 9.4:1
Power : 115 hp@ 6200 rpm & 104 ft·lbf @ 5400 rpm
Head Code : P2J
D16Y7
Found in:
1996-2000 Honda Civic DX/VP/LX/CX
1996-97 Honda del Sol S
Displacement : 1593 cm3
Compression : 9.4:1
Power : 105 hp @ 6200 rpm
Torque (ft·lb@rpm): 103 (141 N·m) @ 4,600 rpm
Valvetrain : SOHC
Head Code : P2F
D16Z6
Found in:
1992-1995 Honda Civic EX/Si, Del Sol Si,
1992-1995 Honda Civic ESi (European Market)
Compression : 9.4:1
Power : 125 hp @ 6500 rpm & 106 ft·lbf @ 5200 rpm
VTEC Switchover 4800 rpm
Head Code : P08
Head Code (EU): P28
Old Jun 2, 2007 | 08:37 PM
ddd4114's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek forever guy &raquo;</TD></TR><TR><TD CLASS="quote">You'll have less power actually, about 30 less hp at the crank.</TD></TR></TABLE>
You sure you're not thinking of swapping an entire z6 engine for a y7?
Old Jun 2, 2007 | 08:44 PM
sleepery7's Avatar
ok well but the the motor isnt really stock again im a noob so if it sounds stupid sorry. the motor has been board out, as to how far not sure also port n polish, full aem exshoust, aem crank pulls, new pistons, the head (z6) has new and cut valves, and my friend gabe just got like stage 2 aem or sum other brand of cams.
so is it worth it or am i still wastn my time
Old Jun 2, 2007 | 08:46 PM
97Ej6mike's Avatar
3-stage VTEC
Found in:
Rod Length : 137 mm
Compression : 9.6:1
Thats what i got
Old Jun 2, 2007 | 08:54 PM
doood's Avatar
been there done that
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by delsolmankiller &raquo;</TD></TR><TR><TD CLASS="quote">ok well but the the motor isnt really stock again im a noob so if it sounds stupid sorry. the motor has been board out, as to how far not sure also port n polish, full aem exshoust, aem crank pulls, new pistons, the head (z6) has new and cut valves, and my friend gabe just got like stage 2 aem or sum other brand of cams.
so is it worth it or am i still wastn my time</TD></TR></TABLE>
you're wasting your time because you dont even know what the engine has done to it. it could be internally stock and you wouldnt know.
Old Jun 3, 2007 | 04:16 AM
Ek Forever y0!
Default Re: power gains (doood)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ddd4114 &raquo;</TD></TR><TR><TD CLASS="quote">
You sure you're not thinking of swapping an entire z6 engine for a y7?</TD></TR></TABLE>
Doh,
Somehow I misread over the head swap. I somehow thought he was swapping in a y7 for his z6
Old Feb 10, 2009 | 09:44 AM
Discreet's Avatar
I want to convert a D15A3 to a D15B. Would this be worth my time? if so, does anyone know of an online tutorial?
tunedk
Apr 15, 2016 07:57 AM
Rocket
62
Apr 26, 2013 09:52 AM
robAP
Jul 4, 2006 06:53 AM
