vtec not kicking at all need help
I blew my b16a a while back just got another put together and running but the head that i used didn't have the vtec solinoid on it so i used the one from my blown motor. I have everything hooked up and full on oil. I do have a vtec controller its a soon one and its hooked up fine also. What can be some things I can try thanks. 1994 Honda Civic Ex b16a
well when i changed my head on my d16 i hear the new Vtec apparently my vtec cant spell the thing right now i am fucked up, was bad, sure thats no the problem?
arguing about if Vtec smokes or not
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94HONDAHEAD »</TD></TR><TR><TD CLASS="quote">I blew my b16a a while back just got another put together and running but the head that i used didn't have the vtec solinoid on it so i used the one from my blown motor. I have everything hooked up and full on oil. I do have a vtec controller its a soon one and its hooked up fine also. What can be some things I can try thanks. 1994 Honda Civic Ex b16a</TD></TR></TABLE>
clean your vtec solenoid gasket. do you have any CEL's?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Exploziveaf1 »</TD></TR><TR><TD CLASS="quote">well when i changed my head on my d16 i hear the new Vtec apparently my vtec cant spell the thing right now i am fucked up, was bad, sure thats no the problem?
arguing about if Vtec smokes or not</TD></TR></TABLE>
jesus christ stop posting
No I don't have any cels and what can I use to clean it and what can I use to clean out the solenoid if that might help also.
Are you autistic?
Try unplugging your vtec controller. It's a good way to see if that's what's causing your problem. I don't think your vtec solenoid would have gotten damaged when you blew your motor.
Are you autistic?
Vtec will only engage when it's at a certain PSI. I'm too lazy to find it right now.
Make sure the pressure is charging.
Maybe the plug or prongs on solonoid plug got damaged or corroded? Use a test light to see if you have power to the solonoid between the solonoid and the plug. Or maybe see if you have continuity from the harness thru the plug to the solonoid side on each wire?
If that is not it, try a buddy's solonoid on your car and use new gaskets. If it works, then something is wrong with your solonoid and will need to get another one.
Good luck!
Good luck!
