First K20(RSX) EG swap
I got a friends RSX that was basicly totaled (so i can pull any parts I want from it)
I need some info on how to do it, I've seen the Hasport write up
but I need info on wiring,which ECU to use, axles, if I can put RSX hub and knuckles on the EG hatch,and how to install the shifter and transmission and some other little stuff
http://rywire.com/store/9295-c...ff082
for a harness
and i hope his rsx was a type s a stock rsx would suck
for a harness
ya its a type s
everything is there and in workin condition the frame is just messed up
I want to put the RSX seats in too and hopefully if i can find info to do a 5 lug conversion with the RSX stuff
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SupraRXZ »</TD></TR><TR><TD CLASS="quote">ya its a type s
I want to put the RSX seats in too and hopefully if i can find info to do a 5 lug conversion with the RSX stuff</TD></TR></TABLE>
As far as I know you can't use the RSX suspension. The have a complete different system (Mcpherson or something like that) than what comes on the older generation civics. It's possible that someone has figured it out but I'm not sure.
k20.org is a good site to learn about the the k series swap. Also, someone has done the seats into a civic, but you have to custom fab the brackets and stuff. And it doesn't look that good IMO. But hey, good luck to you.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aarontrini85 »</TD></TR><TR><TD CLASS="quote">
and i hope his rsx was a type s a stock rsx would suck</TD></TR></TABLE>
why would it suck? Its still a K and its still VTEC so its 160 HP, Big deal if it were dirt cheap from a freind or free none the less no matter what K series it is I would take that thing in a heart beat base is good enough your only out 35 HP about and you dont have to fill up with premium.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jhonny Ricer »</TD></TR><TR><TD CLASS="quote">
It would suck because it's thousands of dollars in parts, labor, fabrication, and wiring for a B16 swap.
</TD></TR></TABLE>It would suck because it's thousands of dollars in parts, labor, fabrication, and wiring for a B16 swap.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jhonny Ricer »</TD></TR><TR><TD CLASS="quote">so what your saying is that extra 35 hp from the type S is worth those thousands of dollars if so than that is pretty moronic
I'm talking about the THOUSANDS of extra dollars past the cost of the motor for a custom header, exhaust, chipped ecu, custom wire harness, mounts, and install labor.
And I wasn't aware that 200 - 160 = 35 ..... might want to touch up on that 2nd grade math.
It's 40 extra horsepower, and a 6-speed transmission. And yes, that is worth far more ... in the same way that a B16B is worth far more than a B16A.
</TD></TR></TABLE>I'm talking about the THOUSANDS of extra dollars past the cost of the motor for a custom header, exhaust, chipped ecu, custom wire harness, mounts, and install labor.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eran »</TD></TR><TR><TD CLASS="quote">
It's 40 extra horsepower, and a 6-speed transmission. And yes, that is worth far more ... in the same way that a B16B is worth far more than a B16A.</TD></TR></TABLE>
Ok so the Type S has 5 more HP than the SI? Because as far as I knew they both used the same motor for the 06 SI and Type S they only rated them at at 195 the JDM is supposedly 200 HP not the USDM, So if they are oh wow I was 5 off point is 40 Hp is nothing comparing a motor, The Type S goes for 5K while the base goes for 1-2K Who cares about the 6th gear if you want it so bad spend an extra grand and get it there its still only around 3-4K, And adding an extra 30-40 HP isnt so hard there you go you have a type S motor for about 4500 500 dollars saved in all realistics your saying that because you get one more gear and an extra 35-40 Hp on the same motor its not worth it? If thats not worth it than neither is LS/VTEC but I see them poping up like the population in china...
Ok so the Type S has 5 more HP than the SI? Because as far as I knew they both used the same motor for the 06 SI and Type S they only rated them at at 195 the JDM is supposedly 200 HP not the USDM, So if they are oh wow I was 5 off point is 40 Hp is nothing comparing a motor, The Type S goes for 5K while the base goes for 1-2K Who cares about the 6th gear if you want it so bad spend an extra grand and get it there its still only around 3-4K, And adding an extra 30-40 HP isnt so hard there you go you have a type S motor for about 4500 500 dollars saved in all realistics your saying that because you get one more gear and an extra 35-40 Hp on the same motor its not worth it? If thats not worth it than neither is LS/VTEC but I see them poping up like the population in china...</TD></TR></TABLE>
Actually depending on which year that motor is from you could be 50 hp off!
2005-2007 had 210 hp.
Also you don't really know anything about K series do you? The base K series doesn't respond well to bolt ons and to make up that 35-40 or 50 hp is going to take alot of $$$. Unless you go turbo thent that is a different story. Another thing too is the design of the engine. The Type-s was really made to kick the **** out of it where as the base model was for fuel economy. Also 6spd tranny makes a difference as the gearing is shorter meaning better acceleration = more fun!
its also a diffrant kind of vtec it has and has alot more potential then the regular rsx.
basilcy if your droping in a stock rsx motor your droping in a b16a there isnt realy a diffrance in any thing the power bands even look close
i dont see how that could be worth probly 5k more then a b16 but what ever its a type s motor he has any way and im sure he will be happy with it plus were getting off topic.
Just if you were wondering the Motor I got is a 05
so its a k20z1, 210hp 143 lbs trq
6 speed EG FTW!
as soon as Im not lazy, I'll get pics of the car and the motor
Modified by SupraRXZ at 4:21 PM 6/3/2007
6 speed EG FTW!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SupraRXZ »</TD></TR><TR><TD CLASS="quote">Just if you were wondering the Motor I got is a 05
6 speed EG FTW!
as soon as Im not lazy, I'll get pics of the car and the motor</TD></TR></TABLE>
that should be fun is it your daily ?? and get hondata kpro and a tune it will be well worth it
6 speed EG FTW!
that extra N/A 50ish hp is a difference of running 15 sec and 12 sec...so yes thats really important
i care about the 6th gear makes the car accelerate faster
with 1-6
as people have said its like comparing b16 to a b18c5...that few extra thousand is worth it...since you will be spending twice teh swap trying to get those extra HP unless your F/I.
with 1-6as people have said its like comparing b16 to a b18c5...that few extra thousand is worth it...since you will be spending twice teh swap trying to get those extra HP unless your F/I.
well since its a brand new motor with less than 10k on it, ya its gunna be a daily lol
</TD></TR></TABLE>well since its a brand new motor with less than 10k on it, ya its gunna be a daily lol
Im not trying to ruin anybodys thread I was just curios as to why people think its not worth it to go base model K.
And thank you for the info. To each his own and i wouldnt mind swapping out my SOHC for any K type S or not.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The Lobster »</TD></TR><TR><TD CLASS="quote">
as people have said its like comparing b16 to a b18c5...that few extra thousand is worth it...</TD></TR></TABLE>
I don't necessarily agree with that, maybe NA, but NA shouldn't be used much in the same sentence as 4 cylinders.
You can buy a B16 and boost it on stock ints and eat up ITR's all day long for less price than it would cost for an ITR swap.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syndacate »</TD></TR><TR><TD CLASS="quote">
You can buy a B16 and boost it on stock ints and eat up ITR's all day long for less price than it would cost for an ITR swap.</TD></TR></TABLE>
your semi right. i guess it really applies mostly to K motors. As an All motor K will easily prepel you into 12s with the type S or R motor with minor bolt ons...include Cams and your good for a good daily driven fast motor.
Zer0ShiFT
Feb 22, 2006 12:30 AM
