which engine wire harness to use? obd1 or obd2
Old Jun 2, 2007 | 02:22 PM
2wheelhunter's Avatar
Default which engine wire harness to use? obd1 or obd2
i have an obd1 jdm b16a, i am gunna put it in a 97 del sol si, so my question is should i used the stock obd2 engine wire harness or the obd1 wire harness on the engine? if i used the obd2 engine wire harness i would have to convert the diz and the injectors... then which ecu should i use? i have an obd1 p28 and an obd2 p28 i know that if i used the obd1 ecu i would need a conversion harness i'm aware of this already... which is the best way to go?
Old Jun 2, 2007 | 03:00 PM
civicsi401's Avatar
Default Re: which engine wire harness to use? obd1 or obd2 (2wheelhunter)
im in this same spot as you atm i have a 93 hatch but has a 99 si wire harness threw out the whole car now i just put a turbo in and need to get the car tuned and put my p28 obd1 ecu in . so yea if you plan on doing some upgrades i would go with obd1 makes things easy for you tunner and your pockets
Old Jun 3, 2007 | 12:40 PM
Default Re: which engine wire harness to use? obd1 or obd2 (civicsi401)
so either would work correct?.. i would just use the obd2 ecu with an obd2 harness and an obd1 ecu with an obd1 harness.. correct me if i'm wrong.
Old Jun 4, 2007 | 04:18 PM
civicsi401's Avatar
u can keep the harness in your car but you will need to get a ecu adaptor harness to run obd1
Austin Gossling
Apr 12, 2017 03:32 PM
jdmshawn95
Jan 14, 2011 11:12 AM
:::SIRll_EJ1:::
14
Feb 18, 2010 04:14 AM
sol-oto
Sep 1, 2009 12:43 PM
vtecftw
Aug 11, 2007 11:15 AM
