OEM VS Aftermarket plug wires
Old Jun 2, 2007 | 01:33 PM
Tyle R_BB6_Boi's Avatar
Default OEM VS Aftermarket plug wires
Im ordering a set of OBX spark plug wires is there much of a difference from the OEM wires? will it help me acceleration at all?
Old Jun 2, 2007 | 02:16 PM
md23vtec's Avatar
Default Re: OEM VS Aftermarket plug wires (Tyle R_BB6_Boi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyle R_BB6_Boi &raquo;</TD></TR><TR><TD CLASS="quote">Im ordering a set of OBX spark plug wires is there much of a difference from the OEM wires? will it help me acceleration at all? </TD></TR></TABLE>
Stock ignition system(cap, rotor, wires, plugs, coil) is good for plenty of power. If anything IMO I would just get just get new OEM replacement parts. Especially over OBX
Old Jun 2, 2007 | 02:34 PM
Default Re: OEM VS Aftermarket plug wires (md23vtec)
I want more acceleration? I just ordered an ACT clutch and fly wheel hearing an upgraded clutch helps with acceleration but ive also heard higher output wires help to what do you think? or have heard?
Old Jun 2, 2007 | 02:39 PM
InvaderTrax's Avatar
Aftermarket plug wires can help a little, but just because OBX claims it helps doesn't mean it will. Get some NGK, Nology, Taylor, or Accel wires
Old Jun 2, 2007 | 02:40 PM
93sivtec's Avatar
Wires will not help with acceleration,unless u are having problems with your current ones functioning properly.
Old Jun 2, 2007 | 03:01 PM
Default Re: (93sivtec)
ALright i saw alittle oil around the hole of the spark plug and the was a little around the end of the wire is that bad or fairly normal the BB6 was purchesed in december i have no idea the last time it had new plugs and wires
Old Jun 2, 2007 | 07:09 PM
Hawkze_2.3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyle R_BB6_Boi &raquo;</TD></TR><TR><TD CLASS="quote">I want more acceleration? I just ordered an ACT clutch and fly wheel hearing an upgraded clutch helps with acceleration but ive also heard higher output wires help to what do you think? or have heard?</TD></TR></TABLE>
An upgraded clutch only grips harder...how would that make you accelerate faster?
Same with plug wires, there is no power to be gained from just plug wires. Get some NGKs and you will have great quality and fitment.
Old Jun 2, 2007 | 07:40 PM
JDMgareth's Avatar
When I check for NGK spark plugs/wires, i can't seem to find them for an h22a.
All listings show for h23's etc, are they compatible or do I need to further my search?
Old Jun 2, 2007 | 07:42 PM
Hawkze_2.3's Avatar
Default Re: (JDMgareth)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMgareth &raquo;</TD></TR><TR><TD CLASS="quote">When I check for NGK spark plugs/wires, i can't seem to find them for an h22a.
All listings show for h23's etc, are they compatible or do I need to further my search?</TD></TR></TABLE>
http://www.prostreetonline.com...e+Set
Old Jun 2, 2007 | 08:08 PM
JDMgareth's Avatar
Default Re: (Hawkze_2.3)
hawkze ftw
can they come in anything else but blue?
Old Jun 2, 2007 | 08:16 PM
Hawkze_2.3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMgareth &raquo;</TD></TR><TR><TD CLASS="quote">hawkze ftw
can they come in anything else but blue?</TD></TR></TABLE>
Thanks, I think the blues are the better quality, while the grey are the lesser quality NGKs...no color choice really.
Old Jun 2, 2007 | 08:37 PM
prelude_93vtec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hawkze_2.3 &raquo;</TD></TR><TR><TD CLASS="quote">
doesnt a lightweigh flyweel help with accelation? i dont know about the clutch but i heard the flywheel does
Old Jun 2, 2007 | 10:19 PM
vinuneuro's Avatar
Default Re: (prelude_93vtec)
http://www.sparkplugs.com
Old Jun 2, 2007 | 10:40 PM
truevietluv636's Avatar
Default Re: (Tyle R_BB6_Boi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyle R_BB6_Boi &raquo;</TD></TR><TR><TD CLASS="quote">ALright i saw alittle oil around the hole of the spark plug and the was a little around the end of the wire is that bad or fairly normal the BB6 was purchesed in december i have no idea the last time it had new plugs and wires </TD></TR></TABLE>
you might need to change your valve cover gasket/seal. oil around spark plugs are bad.
Old Jun 2, 2007 | 10:51 PM
Default Re: (truevietluv636)
Ya i was figuring the valve cover gasket is old im going to autozone tomorrow to pick up a new one thanks
Old Jun 2, 2007 | 10:55 PM
I just read a few post and heard guys saying that the clutch doesnt add horsepower it just sends them to the wheels faster ill have to find the thread same with the wires i know they wouldnt add power but if it ignites the fuel better you have better throdle responce and gain acceleration but that has just what i have read i have not seen any graphs or such to prove these theorys thanks for the reply though
Old Jun 3, 2007 | 11:10 AM
93sivtec's Avatar
As far as the oil.....is there just a little bit on the wire boot,or is your actual plug wet with oil?The 1st is most likely the o rings in valve cover,the wet plug could be worse,like valve seat seal.Hope its not too bad.
Also magnecor makes good plug wires for h22's,and they arent much more than the ngk's,but only come in red,black,and blue.
Old Jun 3, 2007 | 11:23 AM
Hawkze_2.3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93sivtec &raquo;</TD></TR><TR><TD CLASS="quote">Also magnecor makes good plug wires for h22's,and they arent much more than the ngk's,but only come in red,black,and blue. </TD></TR></TABLE>
Back in the day I spent the $70-80 for Magnecors and they did not fit well. The boots would not ever stay on the valve cover Just my experience...
Old Jun 3, 2007 | 11:29 AM
Its just a little tiny bit just enough to notice it!
ill check out those plug wires im looking for red ones so it all works out where do you order most your parts from?[QUOTE=Hawkze_2.3]
Old Jun 3, 2007 | 01:10 PM
93sivtec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hawkze_2.3 &raquo;</TD></TR><TR><TD CLASS="quote">Back in the day I spent the $70-80 for Magnecors and they did not fit well. The boots would not ever stay on the valve cover Just my experience...</TD></TR></TABLE>
Well I personally havent had that problem with them,they fit pretty well,and I picked mine up for around 50$ here at a local import shop.I have seen the red ones on ebay for about the same I belive,but any descent brand wire will do.
Old Jun 3, 2007 | 04:29 PM
The Phil's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyle R_BB6_Boi &raquo;</TD></TR><TR><TD CLASS="quote">I just read a few post and heard guys saying that the clutch doesnt add horsepower it just sends them to the wheels faster ill have to find the thread same with the wires i know they wouldnt add power but if it ignites the fuel better you have better throdle responce and gain acceleration but that has just what i have read i have not seen any graphs or such to prove these theorys thanks for the reply though</TD></TR></TABLE>
That doesn't make any sense at all.
Old Jun 3, 2007 | 04:48 PM
GraphiteMW's Avatar
NGK
ProstreetOnline
Ordered NGK's from them, first time it was lost, 2nd time it was shipped to oregon , then 3rd time i recieved the wires but the plugs were missing not to mentioned the wires were the wrong model. My friend right now is going through a major problem with them as well.
bowtieboy911
Jun 28, 2011 06:13 PM
turismo128
Dec 31, 2007 06:01 PM
Supahr_Ed
17
Jun 3, 2007 08:37 PM
ochsy03
Jun 26, 2005 09:47 PM
