ZC swap into CRX Si trouble
Old Jun 1, 2007 | 04:14 PM
1990crx's Avatar
Default ZC swap into CRX Si trouble
I just bought myself an Si. I took it to a mechanic to have the ZC from my HF swapped into the Si and the Si into the HF. He has everything in but it won't turn over. It will crank but not turn over. He isn't very Honda savy but we did tell him about the 2 wires that differ from the ZC to the Si. I checked the ECU and it throws an error code 15. Please help.
Old Jun 1, 2007 | 06:06 PM
likwid2u's Avatar
Default Re: ZC swap into CRX Si trouble (1990crx)
did he wire the distributor for the new plug? problem with zc twin cam is that the white wires are wrong it will crank but it wont turn on
Old Jun 2, 2007 | 09:27 AM
jlicrx's Avatar
your problem with why you have code 15 (igniter) and it won't start is that you have the HF engine harness on the ZC - you need the Si engine harness - the HF engine harness has the igniter wire in the connector at the firewall on the driver's side - the Si harness has the igniter wire in the connector on the passenger side - wiring harnesses are not interchangeable - the wires in the HF engine harness do not match the wires in the Si chassis harness
Old Jun 2, 2007 | 11:55 AM
1990crx's Avatar
Default Re: ZC swap into CRX Si trouble (jlicrx)
sorry for being so dumb. but can someone post a diagram of what we're talking about cause i went to take a look at it and i can't grasp what we're talking about here. i'm running on 4 hours sleep, no food, and severe heat... please be patient. plus, i'm anxious to get my car going... LOL. thanx and my apologies once again.
Old Jun 5, 2007 | 02:33 PM
likwid2u's Avatar
thats funny cause when i did my swap into my hf the harness needed no modification except for the distributor...... i think your confused with the dx harness....... si and hf are very similar......1990crx just check your distributor plug and look at the white wires on it and see if you got those two wires hooked up correctly
Old Jun 5, 2007 | 03:06 PM
1990crx's Avatar
Default Re: ZC swap into CRX Si trouble (likwid2u)
go to this thread for all updates and solution... http://www.thezcr.com/forums/s...16638
thanks for all your help guys.
Old Jun 5, 2007 | 03:14 PM
jlicrx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by likwid2u &raquo;</TD></TR><TR><TD CLASS="quote">thats funny cause when i did my swap into my hf the harness needed no modification except for the distributor...... i think your confused with the dx harness....... si and hf are very similar......1990crx just check your distributor plug and look at the white wires on it and see if you got those two wires hooked up correctly</TD></TR></TABLE>if you are saying you used the Si engine harness in the HF car and it worked, i say BS - it won't work
Old Jun 6, 2007 | 09:39 PM
likwid2u's Avatar
if you would read it correctlly i said "my hf" that means i used my "hf" harness
Old Jun 6, 2007 | 10:44 PM
1990crx's Avatar
are you sure those two blue wires are still in the same harness? cause when my friend did the initial swap into the HF it wouldn't run without plucking those out and rerouting them.
Old Jun 7, 2007 | 01:01 PM
likwid2u's Avatar
you got to take them from the distributor wiring and run them to the cam sensor
Old Jun 7, 2007 | 01:16 PM
1990crx's Avatar
sounds about right to me...
Old Jun 9, 2007 | 06:15 PM
ZCSp0ngeR's Avatar
i bought a $30 wire harnes from rywired for the crank angle and it looks nice like stock
91 civic si
zc dohc
h22_crx
Mar 10, 2006 04:39 PM
ek_b16
Oct 16, 2005 05:47 PM
SC-MK1
May 22, 2005 08:51 PM
pyro_freak8
Mar 25, 2004 01:30 PM
pyro_freak8
10
Mar 24, 2004 12:10 PM
