s300 problems
Old Jun 1, 2007 | 11:53 AM
ef dino's Avatar
Default s300 problems
i plugged my p28 with the s300 and my car started up at 500 rpm and stayed there.
and its plugged into my laptop also but im getting no feedback at all, it seems likes its just not plugged in.
anybody know whats going on?
its hooked up to my b16 crx.. i got the obd1 dizzy with plugs, and the obd0 to obd1 ecu conversion harness..
it says im online on the bottom left. when i click to upload a calibration it will have the little loading bar in the center of the screen and finish uploading it. but nothing happens. still idles at 500 rpm still cant rev past 4k. what the expletive is going on.
i took the top of the p28 off so you can see the ecu. theres a red light by the usb plug on the hondata chip. and every like five seconds it will switch to green for a split second then go back to a solid red.
and i couldnt find anything wrong with my socketing at all. the only thing was it said to desolder IC3 which i couldnt even find. and i dont have the 4 plug o2 sensor. but i dont think the 4 wire o2 sensor is that important i just want it to run right right now.
Old Jun 1, 2007 | 12:50 PM
riceburner700's Avatar
Default Re: s300 problems (xskiesgoblackx)
have you tryed calling hondata?
Old Jun 2, 2007 | 07:33 AM
ef dino's Avatar
Default Re: s300 problems (riceburner700)
alright finally got that **** working
im pretty sure vtec isnt working though? I have a vss code, eld code, and knock sensor code. I disabled the knock sensor so does that even matter? WIll vtec engage with those codes?
Old Jun 2, 2007 | 10:16 AM
EM1SiR85's Avatar
From: everywhere., cali,nevada,new york., united states
just call hondata.
Old Jun 4, 2007 | 05:56 AM
IT GUY's Avatar
http://www.hondata.net/forum/v...96720
a forum just for you
tempsohc
23
Oct 4, 2015 05:10 PM
craig88crx
Engine Management and Tuning
May 15, 2010 09:39 AM
busdriverj
Jul 23, 2009 04:40 PM
mayndonttripp
Jul 11, 2005 01:54 AM
