Honda S2000 Honda S2000
changing brake pads
Old May 31, 2007 | 09:08 PM
boost4life's Avatar
Default changing brake pads
okay ive searched and on mopnday ima gona help a friend change his pads ive never had to change the rear pads and i heard u needs special tool to compress the rear piston since it needs to be spun when pushed back in is this true b/c i dont want to have to get a special tool
Old May 31, 2007 | 09:10 PM
WowOzYouRock's Avatar
Default Re: changing brake pads (boost4life)
your special tool is C clamp.. lol ... slowly pushing it back though... you dont wanna damage the ABS
Old May 31, 2007 | 09:32 PM
b20integrapower's Avatar
Default Re: changing brake pads (FR-MOB: Jerk)
you can use a c clamp for the rear? i thought you could only use it for the front.
How do you rotate it then?
Old May 31, 2007 | 10:35 PM
Default Re: changing brake pads (b20integrapower)
the parking brake is incorporated into the rear caliper you will have to screw the piston in, not just compress it like the fronts.. if the rear caliper does not have pistons on both sides of the rotor, its the screw in type.. notice how aftermarket caliper with 4 pistons and what not? thats the difference..
you can get the screw in pistion caliper tool at AutoZone for a free loan. $35 deposit, fully refunded once you return of the tool.
Old Jun 1, 2007 | 06:09 AM
S@nt0s's Avatar
Munkyw3rkz.webs.com
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FR-MOB: Jerk &raquo;</TD></TR><TR><TD CLASS="quote">your special tool is C clamp.. lol ... slowly pushing it back though... you dont wanna damage the ABS</TD></TR></TABLE>
or just a screwdriver and put some *** into it
Old Jun 2, 2007 | 11:36 AM
Mr. Projekt's Avatar
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b20integrapower &raquo;</TD></TR><TR><TD CLASS="quote">you can use a c clamp for the rear? i thought you could only use it for the front.
How do you rotate it then?</TD></TR></TABLE>
You stick a flat metal bar in the slots and rotate it clockwise.
Old Jun 2, 2007 | 11:40 AM
Default Re: changing brake pads (Mr. Projekt)
or use the other side of the C clamp... so while youre tighting it, its also rotate...
Old Jun 2, 2007 | 11:41 AM
* B A N N E D *
****** Oz. Fine you win man, I quit.
xxpaulcpxx
Honda Civic (2006 - 2015)
Jul 25, 2010 11:12 PM
ZexyAccord
Honda Motorcycles
Jul 31, 2007 08:12 AM
lowered94accord
Apr 19, 2007 11:46 AM
LudeChild
Nov 16, 2004 05:27 PM
J T*
Apr 23, 2002 04:27 PM
