Suspension & Brakes Theory, alignment, spring rates....
A couple of parts questions (Function 7/A-Spec)
Old May 31, 2007 | 02:01 PM
JjuuN R's Avatar
Default A couple of parts questions (Function 7/A-Spec)
Ok, I recently bought a set of Function 7 LCAs for my 2001 Type R Integra. Also bought an A-Spec 32mm sway bar set up. Now my question is if I should go ahead and purchase the Function7 Rear Sway Bar Endlink Set
and the Function7 Rear Sway Bar Bushing Set.
I'm not exactly sure everything the sway bar kit comes with.
I could call them but want to get some peoples inputs and feed back that have used the products first. Thanks.
Old May 31, 2007 | 03:45 PM
nonsense's Avatar
Default Re: A couple of parts questions (JjuuN R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JjuuN R &raquo;</TD></TR><TR><TD CLASS="quote">I could call them . </TD></TR></TABLE>
No replies in over 1.5hours. Maybe you should have called them?
Those endlinks and bushings are for a stock ITR sway. I'm fairly sure that the 32mm sway kit comes with everything you need including endlinks.
Old May 31, 2007 | 04:35 PM
JjuuN R's Avatar
Default Re: A couple of parts questions (nonsense)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nonsense &raquo;</TD></TR><TR><TD CLASS="quote">
Those endlinks and bushings are for a stock ITR sway. I'm fairly sure that the 32mm sway kit comes with everything you need including endlinks. </TD></TR></TABLE>
True that hehe.
Old May 31, 2007 | 07:34 PM
Han Solo's Avatar
32mm sway bar!!! THATS HUGE
Old May 31, 2007 | 08:18 PM
JjuuN R's Avatar
Default Re: A couple of parts questions (VTECommie)
That's what she said.
Old Jun 1, 2007 | 07:08 PM
chinoty's Avatar
The fuctions 7 and blox are very identical i suppose, since both are made out of heim joint. I have purchase the blox and found out these heim joint setup do not sit that well. For some reason, it tilts in a angle and are not set up how its suppose to... I end up using my stock ones. I have a set for sale if anyone are interested in giving it a shot...
Old Jun 1, 2007 | 09:01 PM
JjuuN R's Avatar
Default Re: A couple of parts questions (chinoty)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chinoty &raquo;</TD></TR><TR><TD CLASS="quote">The fuctions 7 and blox are very identical i suppose, since both are made out of heim joint. I have purchase the blox and found out these heim joint setup do not sit that well. For some reason, it tilts in a angle and are not set up how its suppose to... I end up using my stock ones. I have a set for sale if anyone are interested in giving it a shot...</TD></TR></TABLE>
Pics, installed and un-installed?
Old Jun 3, 2007 | 08:57 AM
chinoty's Avatar
I dont have any picture of the Blox Endlinks in stalled. Like I said it was b*tch to put in. If there is pictures I would to see some as well..
Old Jun 4, 2007 | 11:23 PM
Function7's Avatar
The ASR kits are compatible with our arms. The kit should come with sway bar linkages and all you need is a longer bolt plus a nut to bolt the linkage to the arm.
-A
Old Jun 15, 2007 | 09:17 AM
JjuuN R's Avatar
Default Re: A couple of parts questions (Function7)
Ok cool, thanks for the information.
vega5415
Apr 25, 2013 09:36 PM
thegreat0ne
Aug 24, 2007 09:29 PM
hamburgler
15
Feb 20, 2007 04:42 AM
unknown2
Sep 2, 2004 06:29 PM
DeSolMan007
Apr 7, 2003 08:22 PM
