sway bar(dont hate me ha)
ok i tried searching and didnt find anything.ok i have a 95 integra sway bar and control arms my friend said i need the beaks so i dont f anything up or can i just bolt it up?is this true or is that only for the itr rear sway bar? thanks everyone
Re: (ItR_98)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ItR_98 »</TD></TR><TR><TD CLASS="quote">the beaks kit is for a type r sway bar. since the type r sway bar has a thicker diameter, it has been known to damage non-type r sub frames.</TD></TR></TABLE>
yep...plus it adds a little flash to your rear end...though you can't be the asr application...
Re: sway bar(dont hate me ha) (hamburgler)
i have a gsr rear sway bar on my car, didn't need any reinforcement. I race it at the track to and so far so good.
Re: sway bar(dont hate me ha) (pkdog167)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pkdog167 »</TD></TR><TR><TD CLASS="quote">Only 99 civic si and integra/civic type-r's sway bar need brace </TD></TR></TABLE>
99 si sway bar is a dinky 13mm, as stated a couple times above
you only need (well, you dont NEED it, but its reccomended) a reinforcement kit with a bigger bar like an itr
bumpbump pics and more info
ps are you guys using bolts and nuts from the hardware store to mount them it to the subframe
If you need pics then go to ASRs website or do a search for subframe tearout. Unless you need a pic of a rear swaybar, which I can't think of any reason why. You can just peak under an Integra or certain models of Civics. It's nothing special.
You don't need reinforcement for any bar under 18mm. And if you get a well designed bar (Progress), then you can run an adjustable 24mm without the expense and weight of subframe reinforcement. I've been running that bar on the street for 3 years. I take it off occassionally to re-lube the bushings, and there is no sign of stress or tearing.
The only respectable subframe reinforcement IMO is to reinforce-weld the subframe, mimicking the ITR. Everything else is just for show. The ASR especially. It's just a big plate made of expensive metal with expensive cutting and etching.
HT White Ops
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hamburgler »</TD></TR><TR><TD CLASS="quote">bumpbump pics and more info
ps are you guys using bolts and nuts from the hardware store to mount them it to the subframe</TD></TR></TABLE>
Usually, most people do. No point in paying $2-6 per bolt at Honda. Make sure you get SAE Grade 8 or Metric Grade 10 bolts. Strength
Re: sway bar(dont hate me ha) (Targa250R)
thanks everyone im goin to the hardware store later today. will i even be able to tell a diff in the car with it on(going from no sway bar to a integra sway bar).sry about sounds like i noob and stuff i just like to have all my info before starting something.
to the people that have helped
