hard shifting into first and second.
its hard to shift into first, second, and reverse. sometimes i have to force it in. clutch master cylinder is good, new slave cylinder, clutch pedal adj. new clutch. all other gears work good.
i was thinking it could be the two bolts on the bottom of the tranny casing. the bolts with the springs at the end. i think they hold the shift fork in place. do they have washer on them? mine dont, and also they are leaking a little. i tried to snug them but then the shifter is as hard as a rock.
jdm_phunk
Feb 27, 2011 05:17 PM
havikprelude
Transmission & Drivetrain
Nov 10, 2009 12:22 PM
hspoon
Nov 20, 2006 10:38 AM
