How do I get to this?
Old May 30, 2007 | 12:44 PM
citrus3000psi's Avatar
Default How do I get to this?
Img courtesy of another thread.
I have something loose in my dash it moves back in forth...but only when the car is on the edge. Needless to say i've dealt with the problem for a while but since expo is here i want it fixed before i go. So...I've almost comitted to taking out the dash cause I can't find the SOB anywhere.
But looking at this picture I think the bolt or whatever is in that compartent. It sounds like its metal on metal and can move back and forth about 3 feet. That white "tunnel" would be prime spot for it... So question is can I get to that without taking out the dash? Can I go through the hood.
Thanks
-Dan
Old May 30, 2007 | 12:48 PM
98DC2R's Avatar
Default Re: How do I get to this? (citrus3000psi)
you will have to pull the dash to get access to that. that is for your defroster on the windshield and side windows. sorry
Old May 30, 2007 | 12:51 PM
ITR640's Avatar
If it is metal you could try and fish it out with a magnent.
Old May 30, 2007 | 12:53 PM
r573's Avatar
Default Re: (ITR640)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITR640 &raquo;</TD></TR><TR><TD CLASS="quote">If it is metal you could try and fish it out with a magnent.</TD></TR></TABLE>This sounds like a good start!!!!!
Old May 30, 2007 | 12:56 PM
Mugen Mike's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by citrus3000psi &raquo;</TD></TR><TR><TD CLASS="quote">can I get to that without taking out the dash? Can I go through the hood.</TD></TR></TABLE>
Sure. You could drill a hole through the firewall.
Old May 30, 2007 | 12:57 PM
RTW DC2R's Avatar
wont taking out your dash just increase the chances of causing other squeaks and rattles?
Old May 30, 2007 | 01:40 PM
mstewar's Avatar
Default Re: (RTW DC2R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RTW DC2R &raquo;</TD></TR><TR><TD CLASS="quote">wont taking out your dash just increase the chances of causing other squeaks and rattles?</TD></TR></TABLE>
if you are careful putting everything back together and snug bolts/screws properly, it would actually be more likely to stop all rattles and squeaks.
it's really fairly easy to pull the dash.
Old May 30, 2007 | 01:50 PM
davidnyc's Avatar
http://www.hondahookup.com has the ITR/Integra Helms manual.... I downloaded the file myself and will be taking my dash out soon for a safety modification.
Old May 30, 2007 | 02:10 PM
I already have most of the dash taken part. Just havn't taken the 8 bolts out, radio. Otherwise mostly everything is out from me trying to trace down the bolt.
I already have a helms and have looked at the procedure. It doesn;'t seem hard but like i said if there was an eaiser way i wanted to know it.
So looks like the dash is coming out.
Old May 30, 2007 | 02:16 PM
JjuuN R's Avatar
Default Re: (citrus3000psi)
DAMN!! Sucks citrus having to do all the work for some petty crap like that, I know it bugs the hell out of you though, it would me!
Old May 31, 2007 | 05:59 AM
And what I can't figure out i show it got in there or where ever it is. I don't have people in my car that would just drop a bolt down the dash for jokes. So...I don't know.
Old May 31, 2007 | 02:52 PM
pvt_awol's Avatar
I hear that dude. I rolled in my R for months listening to a metallic rattle rolling around "somwhere" in the car whenever I'd accelerate or brake. It was so annoying. When I started ripping things apart, I found a 6" socket extension and 10mm socket in the floor pan! I don't even know how it got there, because it was hard as hell to get it back out. I feel your pain man.
Old May 31, 2007 | 03:13 PM
mugenracer's Avatar
Theres a little black cover right in the middle of the dash, pry it out with a screw driver and stick a magnet in as far as you can get it (a reasonable sized one) and then go out for a drive on the twistiest road you can find and hope that what ever it is rolling back and forth gets caught by the magnet.
Old May 31, 2007 | 06:08 PM
SS b0i R3DD SS's Avatar
jus go through the dash. plain and simple. but make sure the nuts and bolts are put back safely.as mentioned b4.
Old May 31, 2007 | 08:36 PM
ITR#132's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by citrus3000psi &raquo;</TD></TR><TR><TD CLASS="quote"> So question is can I get to that without taking out the dash? Can I go through the hood.</TD></TR></TABLE>
you can access that area by removing the black "cowl" under the windshield wipers.
fit2bee
Honda Fit
May 19, 2018 11:56 AM
nik4537
Mar 25, 2008 04:53 PM
Gaspar_06_Civic_EX
Honda Civic (2006 - 2015)
10
Jul 10, 2006 10:22 AM
Drakko
Audio / Security / Video
Jul 10, 2004 07:46 AM
pip9
Dec 8, 2003 07:11 PM
