vacuum lines HF>SI ????
here are vacuum lines in the box on the firewall for HF - you will only need numbers 7, 12 & 21
this is where they are on the HF engine
this is where they are on the 89-91 Si MPFI engine (88 is a little different)
this is 88
this is 88
Oh right Cali... Is it a Cali emissions manual EX sedan MP6 perhaps? Thats the only PM6 I've ever heard of having EGR. Good luck with that, I'd get a non egr PM6. Other than that I dono.
vacuum lines will depend on what engine it is - essentially, for the engine to run right (if it doesn't have EGR) you only need vacuum line from throttle body/intake manifold to the MAP sensor and vacuum line from the intake manifold to the fuel pressure regulator
classciv
11
May 9, 2007 03:51 PM
rice a roni
Dec 8, 2006 07:55 AM
rice a roni
Dec 4, 2006 01:22 PM
