Problem with relay
My relay is flickering dont know why it a good relay i have 3 of them and they do all the same and the ecu light flickers to the engine light flickers to and wont turn off. DOnt know what wrong need help. the main relay. 0063
almost sounds like you may have a line shorted or coming loose between the ecu and relay. a voltage meter can help you out, check for non ground lines to have continuity to your chassis ground.
I figured it out it was the ground on the thermostat i got confused and for got to bolt it up I have had some problems with the wiring on my car i had to pull the whole harness and had to test it out side and then put it back in side. I think it had a bad ground some where Also my left cluster turn signall blew on the cluster gauge on the back. It burned out like a fuse. Not sure it there is any diff with a nippon denso or the one i have a nippon seico.
anthonylee29
Jan 29, 2006 07:40 PM
