timing belt and 90000 service
I paid $711 at the dealer for my 98 V6 and it included
cabin filters
tire rotation
all fluid changes (PS brake and coolant)
brake adjustments and caliper lube
oil change
air filter change
atf change
suspension check
car cleaned inside and out
V6 Egr recall and valve replacement
cabin filters
tire rotation
oil change
air filter change
atf change
suspension check
year? make? model?
@round $700 sounds right. for most accords, years 90 to 2002.
you could save yourself a ton of money by calling around for quotes ahead of time.
otherwise you could save yourself even more money and do it yourself.
I did my accords timing belt, water pump, and all that for about 400.00 myself. Its pretty straight forward if you have the service manual.
I was able to pull it off for $130 for new timing belt, balancer, tensioners, waterpump, seals, and gaskets and of course 12hrs of my time( 1st try).
If you're not a DIY then I dont suggest trying it. You could seriously damage your engine. Expect to pay between 600-1000 for everything,shop around...
LoveDeezNutz
Mar 10, 2011 07:27 PM
hatchydude
Jul 17, 2005 04:49 PM
dmcivic
20
Oct 8, 2004 09:19 PM
