brakes changing idle
I have a crx with b16,I noticed my idle was way lower than usual today, under 500 rpm and when stopped if I push my brake pedal it drops even lower than goes back up when I let off. Anyone had this problem before?Thought it was going to kill a few time but didn't.
Yep, there is a large (about 1" diameter) vacuum hose running from the far driver's side of the back of your intake manifold to the power booster on the firewall. The whole vacuum system is intertwined.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Wes V »</TD></TR><TR><TD CLASS="quote">There should be a check valve in the line that goes to the brake booster.
I'd try replacing that first.
Wes</TD></TR></TABLE> or just check air should only flow through one way
DUKE LADUKE
25
May 10, 2011 09:21 AM
FearTheH
11
Apr 13, 2009 05:03 AM
djnikko
Mar 8, 2004 05:54 AM
