Will i pass emissions?
Old May 30, 2007 | 08:45 AM
hip_hop_s0ulchild's Avatar
Default Will i pass emissions?
I'm not sure if this is in the right section... but:
I just got back from testing my car.
Cruise Emissions:
HC(PPM) - 517
CO(%) - 9.6
The operator said HC(PPM) was too high, its suppose to be at 170 I believe he said? Also the CO(%) was suppose to be at 1.2
How can I fix the problem?
Thanks.
Old May 30, 2007 | 10:46 AM
xcthc's Avatar
Default Re: Will i pass emissions? (hip_hop_s0ulchild)
saying what you've done to your engine might help
Old May 30, 2007 | 07:17 PM
Default Re: Will i pass emissions? (xcthc)
its stock.
Old May 30, 2007 | 08:54 PM
dude_123's Avatar
You are running too rich, it's a gross poluter. Check your timing, spark plugs, distributor cap, spark plug wire, and cat for proper operation and specs. Replace the O2 sensor/s if it has not been replaced for about 70k-80k miles.
Old May 31, 2007 | 06:36 AM
Scott_Tucker's Avatar
Default Re: Will i pass emissions? (dude_123)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dude_123 &raquo;</TD></TR><TR><TD CLASS="quote">You are running too rich, it's a gross poluter. Check your timing, spark plugs, distributor cap, spark plug wire, and cat for proper operation and specs. Replace the O2 sensor/s if it has not been replaced for about 70k-80k miles. </TD></TR></TABLE>
You are right in saying it's rich - way rich - but replacing any of the secondary ignition parts (plugs, etc.) isn't going to help a bit. He needs to figure out why he is running so rich. 9.6% CO is way high and I'm surprised the car even runs with it running that rich.
Does it even have a cat? Any thing that causes more fuel to enter the engine is going to make it rich (excessive fuel pressure, open coolant temp sensor, etc.).
Old May 31, 2007 | 09:58 AM
chicows18's Avatar
The car is dumping way too much fuel in the chamber and not burning it all up. Check fuel pressure regulator. Timing cant be off since it went to smog. O2 sensor would also cause this problem. But most likely its fuel pressure regulator. Since O2 would set a check engine. Also, what year is it?
Old May 31, 2007 | 10:10 AM
HAMOTORSPORTS's Avatar
What are your o2 readings and n0x?
SLOWEF1990
10
Oct 13, 2018 02:15 AM
coldpimpin
Apr 10, 2007 08:41 PM
SLO Sol
11
Nov 16, 2005 05:51 AM
HmgLauj69
Jul 17, 2004 05:23 PM
SIK IN DA HED
Nov 22, 2002 03:43 PM
