no wiring needed if its si?
Old Jun 3, 2002 | 10:47 AM
wizzards581's Avatar
Default no wiring needed if its si?
would a hatch si need wirings if b18 (GSR) was to drop in... i heard all wirings will plug in...
Old Jun 3, 2002 | 10:48 AM
94HybridEX's Avatar
Default Re: no wiring needed if its si? (wizzards581)
If motor is OBD I and you get OBD I ecu it's easy. It gets a little harder if ecu/motor are not obd I.
Old Jun 3, 2002 | 10:54 AM
B_CRUZ!'s Avatar
you would still need to wire a knock sensor and secondaries.... unless you use a skunk2 im, chipped p28 ecu which doesn't look for a knock sensor.
an obd2 motor in a obd1 car is no problem. its the same amount of wiring.
Old Jun 3, 2002 | 10:55 AM
Default Re: no wiring needed if its si? (B_Cruz)
so will the 94-97 GSR ecu fit rite in my stock civic si?
Old Jun 3, 2002 | 11:58 AM
slomofo's Avatar
GDD Member
94-97 will fit in your si, but 97 is OBD-II, so you'd have to get a 2nd 02 sensor, a jumper or pigtail to plug in the ECU, and some other **** too.
Old Jun 3, 2002 | 10:22 PM
Default Re: no wiring needed if its si? (slomofo)
so ur saying the obd1 GSR ecu will jux plug rite in while takin the stock si ecu out.?
diyeealooen
19
Aug 7, 2010 06:04 PM
fireant
Jul 2, 2008 01:58 PM
Elevorett
Feb 14, 2007 05:35 PM
96b18c
Nov 2, 2005 12:05 AM
Duck*
Aug 4, 2003 12:58 AM
