How big rear sway bar on an EJ6....is too big bad ?
I heard that going to big on the rear sway bar is bad, like 32mm for example...
I just want the absolute best handling possible, which sway bar should I get and how big? Would good tires eliminate the oversteer understeer problems, or whichever it is?
What about the ITR sway bar, would that be a good choice? Its like 22m or 23m depending on USDM or JDM right? Not really sure...
Help
Help
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spaceman00 »</TD></TR><TR><TD CLASS="quote">what do you mean by insane...
im really curious why many ppl say 32mm are better but not to put them on... ?</TD></TR></TABLE>
Have you ever looked at a 32mm hollow bar?
They're for <u>track use only</u>, your car will become nigh unstreetable. They completely neutralize any understeer. Your rear end will be one solid unit that will not flex except under extreme situations.
If you don't know why you shouldn't use one, then your car isn't hardcore enough to use one.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eran »</TD></TR><TR><TD CLASS="quote">
If you don't know why you shouldn't use one, then your car isn't hardcore enough to use one.</TD></TR></TABLE>
couldn't say it any better.
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Team RS2 »</TD></TR><TR><TD CLASS="quote">whats wrong with driving a full race car on the street????
it's unsafe, and when you run 118 octane on the street its expensive.
</TD></TR></TABLE>it's unsafe, and when you run 118 octane on the street its expensive.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GarageAlchemist »</TD></TR><TR><TD CLASS="quote">it's unsafe, and when you run 118 octane on the street its expensive.</TD></TR></TABLE>
Suspension doesn't alter the octane needs of your engine.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus »</TD></TR><TR><TD CLASS="quote">
Suspension doesn't alter the octane needs of your engine.</TD></TR></TABLE>
lol
lol
Go with an ITR bar, or companies like Mugen and Cusco make them in 25-26mm, but I wouldn't even recommend that for the street.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spaceman00 »</TD></TR><TR><TD CLASS="quote">Would good tires eliminate the oversteer understeer problems, or whichever it is?
you should probably learn and understand what these terms actually mean, and how they effect your car before messing with your suspension...
on a fwd car for the best neutral handling you want a big rear sway bar, or stiff rear springrates...and if you read ASR's website the 32mm hollow bar is the same stiffness as the 26mm mugen bar, but on like they said above, 22-23mm will be fine for street
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eran »</TD></TR><TR><TD CLASS="quote">Get a CTR (22mm) or ITR (22mm or 23mm).
Don't get a 32mm bar. They're ******* INSANE, drag only basically.</TD></TR></TABLE>
Hahaha...
dude, that thick *** ASR bar is NOT made for drag racing. It's for road racing.
Hahaha...
actually drag racing hondas specifically for dragracing, actually take the rear discs off of it ans swap drums on it, take BOTH sway bars off, said to wiehg damn near 40 pounds together and the drum conversion saving 14 pounds, check out the drag race forumn they dnt joke around there
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ1 wilcox »</TD></TR><TR><TD CLASS="quote">
Hahaha...
That's what I meant. I typed the wrong word.
Hahaha...
