Skunk2 IM whistle??
Old Jun 3, 2002 | 09:07 AM
BoostedGSRBubble's Avatar
Default Skunk2 IM whistle??
I installed some new parts this weekend and a Skunk2 Intake Manifold was one of them. I used the hondata gasket too. When I accelerate hard it whistles. I'd think its air being sucked in between the head and the gasket or the gasket and the manifold. I dont think this is a good thing b/c it is not filtered. My question is has anyone else had this, is it normal? Should I over torque the nuts since the gasket is thicker and plastic?
Old Jun 3, 2002 | 12:04 PM
Default Re: Skunk2 IM whistle?? (trustsi)
someboy has to have had this problem, i've read it on here before.
TTT
Old Jun 3, 2002 | 12:24 PM
10seconds's Avatar
Honda-Tech User
Its normal. Every SKUNK2 manifold I have seen on a GSR whistles.
steve
Old Jun 3, 2002 | 12:29 PM
Spade's Avatar
Default Re: Skunk2 IM whistle?? (jdmimports79)
Check the gaskets. Spray some carb cleaner with the engine running around the manifold and find where the leak is.
Old Jun 3, 2002 | 12:44 PM
555R's Avatar
cant say i have any whistling with my car
could be air rushing past the throttle plate also
Old Jun 3, 2002 | 01:03 PM
Kamin's Avatar
Default Re: Skunk2 IM whistle?? (555R)
yes it sounds like you have a leak in the intake manifold gasket
is the idle a little higher than normal?
spray the carb cleaner and see if it stops/goes away.
Old Jun 3, 2002 | 01:21 PM
Briman2021's Avatar
Default Re: Skunk2 IM whistle?? (KAMiN)
jsut a quick question. Why carb cleaner?? What makes it special??
Thanks, I have heard this mentioned many times before and I never understood it.
Old Jun 4, 2002 | 12:25 AM
C4wrx's Avatar
Default Re: Skunk2 IM whistle?? (Briman2021)
yah my skunk2 manifold whisltes, 3 out of 4 of me and my friends cars whistle
Old Jun 4, 2002 | 07:28 AM
6ghatch's Avatar
Default Re: Skunk2 IM whistle?? (Jdmb18c)
Yeah, mine whistles under acceleration and when I get off the throttle. It only does it when the engine is under load so when I rev the car sitting, it is very hard to hear. Everywhere I take it people think it's normal, I'd like to find out if it is a leak. Let me know If you find out anything.
Old Jun 4, 2002 | 09:30 AM
Default Re: Skunk2 IM whistle?? (6ghatch)
Thanks all for the replies, im going to try the carb cleaner after work today. Will it FIX it or leak out so i can find the leak? For those of who who say it's normal, did you torque the nuts to spec or just crank them down? Normal/common makes me feel a little better but it dosent mean its right or a good thing. I will keep everybody posted.
And yes my idle is a little high, I thougt it was the mugen program that I installed at the same time, good point though.
[Modified by trustsi, 6:32 PM 6/4/2002]
Old Jun 4, 2002 | 10:07 AM
rodrez.'s Avatar
Mine whistled when I put it on. A few months later, when I installed an ITR throttle body, it whistled a little louder, but it didn't affect performance negatively, so I'm cool with it.
Old Jun 5, 2002 | 09:11 AM
IMSTOCK's Avatar
Default Re: Skunk2 IM whistle?? (rodrez)
Nothing to worry about. My Skunk whistles also. I think its because of the larger inlet. im not to sure. But its deffinately nothing to worry about. Besides its cool when ricers think its a turbo.
Old Jun 5, 2002 | 09:15 AM
B_CRUZ!'s Avatar
you spray carb cleaner arounfd the flanges and if the idle changes while you are spraying it, then you have a leak. i just noticed mines whistles too under load and my idle is high also. i thought it was the mugen program i installed, but it seems to idle high on my stock ecu as well.
Old Jun 7, 2002 | 12:31 PM
Default Re: Skunk2 IM whistle?? (B_Cruz)
yup, i got a leak. i sprayed carb fluid and sure enough my idle went down. So I went to tighten some of my nuts up and some were loose!! So I put blue locaite onthem and cranked them down to 2lbs over reccomended pressure. No whistle and my idle is down to 750 where it should be. Mad love to all who helped, Thanks guys!
imcnblu
Apr 5, 2012 02:28 AM
Civic98KH
Apr 25, 2007 08:32 AM
IlIkEg's
Mar 22, 2006 06:55 PM
Rusty Shackleford
Nov 22, 2003 11:41 AM
Spyder500
Jul 5, 2002 11:50 PM
