GSR Front or Rear Sway Bar Fit EK Hatch?
Old May 29, 2007 | 05:37 AM
JLEK's Avatar
Default GSR Front or Rear Sway Bar Fit EK Hatch?
Will either the GSR Front or Rear Sway bar fit the EK Hatch?
Old May 29, 2007 | 06:18 AM
Libertariat's Avatar
Ek Forever y0!
Default Re: GSR Front or Rear Sway Bar Fit EK Hatch? (JLEK)
The front strut bar will bolt up. But for the rear sway you'll need aftermarket arms.
Better to just buy an aftermarket subframe brace and a 22/23 mm sway from a manufacturer. You can't just use the sway without the brace.
Old May 29, 2007 | 07:31 AM
JLEK's Avatar
Default Re: GSR Front or Rear Sway Bar Fit EK Hatch? (ek forever guy)
will the front sway bar bolt up? maybe with si endlinks and forks?
Old May 29, 2007 | 07:43 AM
JMelt4's Avatar
Probably not. I think only the EX/Si EK's came with LCAs that could accept Sway Bars. You will almost certainly have to use Aftermarket LCAs or Integra LCAs (which are my recommendation).
Old May 29, 2007 | 08:50 AM
JLEK's Avatar
Default Re: GSR Front or Rear Sway Bar Fit EK Hatch? (JMelt4)
will integra lca bolt up the the ek?
Old May 29, 2007 | 08:56 AM
truevietluv636's Avatar
it should bolt up for the fronts.
Old May 29, 2007 | 06:47 PM
JMelt4's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JLEK &raquo;</TD></TR><TR><TD CLASS="quote">will integra lca bolt up the the ek?</TD></TR></TABLE>
Integra LCAs will bolt up all around.
Old May 30, 2007 | 01:47 PM
B18aCRiX's Avatar
dont use a integra fron sway bar... the clearance sucks... wen i put my jdm itr sway bar i had 2 inches from the ground so i just took it off..
Old Jun 1, 2007 | 10:42 AM
speedball3's Avatar
All EK rear lower control arms are the same. To use the GSR rear sway, you'll need all the mounting hardware for an Si rear sway.
see:
https://honda-tech.com/zerothread?id=1811253
vital info from thread:
ES OEM Replacement Bushings: $9 @ autozone
Si Brackets: $25 from Honda
Si/CR-V endlinks: $10 from a junkyard
Misc Bolts: $1.xx at a hardware store
Good luck.
Old Jun 1, 2007 | 10:57 AM
instrument's Avatar
2 inches of clearance?
i hope you arent one of those people who put their front sway bars on upside down *L*
a few people have posted here "Why is my sway bar so low"
anyway, they will fit, just get the si front arms so you won't have to use some weird mounting bracket.
Old Jun 1, 2007 | 02:37 PM
B18aCRiX's Avatar
yea actually now that i think about it i think i did mount it wrong..
im actually using ex lcas
Modified by B18aCRiX at 3:57 PM 6/1/2007
Old Jul 27, 2007 | 06:24 PM
RyanA's Avatar
Default Re: (B18aCRiX)
Front Teg sway on upside down or right side up, they are WAY too low to the ground. Took mine off today and put on an EX front sway so I could get the car on an alignment rack. How the heck can you put it on upside down anyway?? If you put it on upside down, it would hit the rear of the lower control arm where it mounts to the body....
jdmsir4dr
Suspension & Brakes
Apr 27, 2015 07:56 AM
Teh Boss
Dec 30, 2012 07:48 PM
Diamond Co
Suspension & Brakes
12
Dec 3, 2012 08:39 AM
Santys EK
Aug 12, 2006 07:51 AM
DC2#309
Apr 5, 2005 07:54 PM
