GSR swap Ek, what upper radiator hose?
The GSR radiator hose is to be used, but the problem with using the stock civic radiator is the inlets are of a smaller diameter but if you tighten it down properly then it shouldn't be much of a problem. If your using the screw tightening clamps, then you might want to switch them with the push and lock type.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by capitol J »</TD></TR><TR><TD CLASS="quote">The GSR radiator hose is to be used, but the problem with using the stock civic radiator is the inlets are of a smaller diameter but if you tighten it down properly then it shouldn't be much of a problem. If your using the screw tightening clamps, then you might want to switch them with the push and lock type.</TD></TR></TABLE>
push and lock?
the hose looked fine, wasnt cut or had holes thats why we didnt buy a new one. could it just be an ageing hose?
push and lock?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cheesee »</TD></TR><TR><TD CLASS="quote">
push and lock?
the hose looked fine, wasnt cut or had holes thats why we didnt buy a new one. could it just be an ageing hose?</TD></TR></TABLE>
By push and lock i just mean the original. And it could just be an old hose but if it looks fine then it should be okay, but if it's just seaping out between the hose and the in & outlets, then it should just have to be readjusted and tightened
push and lock?
By push and lock i just mean the original. And it could just be an old hose but if it looks fine then it should be okay, but if it's just seaping out between the hose and the in & outlets, then it should just have to be readjusted and tightened</TD></TR></TABLE>
oh we had those on their before and it was too big, with the others it stoped a lot. we're probably going to flush out the radiator so might as well just get a new hose.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crackerjacker006 »</TD></TR><TR><TD CLASS="quote">i used a screw tighten hose clamp with a gsr upper radiator hose and it works fine just have to tighten it a little more cause inlets are smaller</TD></TR></TABLE>
yeah thats what we are using. i guess i should've replaced the upper rad hose while it was out. time for a new
jeremy.
Mar 1, 2004 12:47 PM
Flamenco-T
Feb 25, 2003 12:53 PM
