Cut wires-JDM Headlights EG6
Old May 28, 2007 | 08:57 PM
hafaadaiteg's Avatar
Default Cut wires-JDM Headlights EG6
Which wires do i connect?? from the jdm heads to the usdm wires???
what about the h4 to h4h change in bulb??? umm what do they look like??
where can i get the city light bulbs?? how do i connect those to the wires...( i want my sidemarkers to stay on but turn when i signal..with the coners flashing at the same time...can someone help??
is there and THREAD out there that meet my standards??
Old May 28, 2007 | 09:39 PM
Default Re: Cut wires-JDM Heads EG6 (hafaadaiteg)
anyone?
Old May 28, 2007 | 10:37 PM
bpkmrtoes's Avatar
uhh... the plug is the same the bulbs is what is different. the h4h bulbs are smaller and wont sit in the usdm housing. i think the stock clips from the sidemarkers fit the city lights too but it should have come with the head lights... the correct way to wire city lights is to cut red from corner and ground black. then side markers is to ground black wire then positive tapped into green from corner.
this set up (japanese config) would have
1st click:
city lights on, side markers/corners off and only on when signaled
2nd click:
headlamps on, sidemarkers/corners off and only on when signaled
::i think:: if u want the sidemarkers to stay on and blink.. u just need to tap the sidemarkers ground into green instead of black. so sidermarker red to corner red, sidemarker ground to corner green. this is the case with non city lights.. im not sure when u throw city lights into the mix... but it should be like this too
Old May 29, 2007 | 10:03 PM
Default Re: Cut wires-JDM Heads EG6 (bpkmrtoes)
thanks a lot...hey i have a short in my wires i think...umm my corners and tailights dont turn on at all...i try to put new fuses in but nothing works??
where can i check my wires for the short??
eg-6 life
Oct 4, 2010 09:57 PM
primaryOBSESSION
Mar 21, 2010 11:51 AM
J3rm
Aug 6, 2007 01:42 PM
beginnerCivic
Audio / Security / Video
Sep 9, 2003 05:10 AM
FR-MOB: ThE bEe GuY
Apr 24, 2003 07:50 AM
